Thread: Air Condition
Results 1 to 5 of 5
  1. #1 Air Condition
    Nov 2011
    Bala ON.
    Hey guys kinda new at this. I previously owned a 2002 Grand Prix , loved it. Now I just purchased a 2005 Grand Prix It's in mint condition, but the Air does not work. the Air in my my old 2002 also did not work. Is there a quick cheap solution to get this problem fixed.
  2. #2 Re: Air Condition
    Well we kind of need some more infomation like what have you checked? Does it not work at all or does it only work on certain settings? Is the compressor making any noise. Have you checked the refrigerant level?
    04 Comp G.
  3. #3 Re: Air Condition
    turn the ac on check to see if the compressor middle part is turning, if not it likely out of freon, so it has a leak that needs to be found and repaired then re filled.
  4. #4 Re: Air Condition
    Nov 2011
    Bala ON.
    OK thanks I will check the compressor.
  5. #5 Re: Air Condition
    SE Level Member sexxy1969's Avatar
    Nov 2013
    MA
    You might need a sensor. The only is if it's like my car you will need a couple of different sensors.
  1. No start condition. Please help
    By Phurst in forum General Tech Discussion
    Last Post: 06-25-2010, 09:44 AM
  2. Rich Condition HELP!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 04:51 PM
  3. GTP lean condition
    By gerhardt02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2009, 07:55 PM
