Thread: 04 Fuel Line
Results 1 to 6 of 6
  1. #1 04 Fuel Line
    Dec 2012
    Maryland
    Trying to find a replacement fuel line for my 04 GT2. Every where I've gone says GM does not have a replacement, it has to be fabricated?
    Anyone else run into this or does anyone have a lead on a new replacement? (junk yard is the last resort)
  2. #2 Re: 04 Fuel Line
    Aug 2013
    arlington, tx
    Why do you need to replace the fuel line?
  3. #3 Re: 04 Fuel Line
    Dec 2012
    Maryland
    Rusted pretty bad right on the bend, rear of the wheel well, I want to replace it before it starts leaking and becomes a problem.
  4. #4 Re: 04 Fuel Line
    Aug 2013
    arlington, tx
    Ahh ok. Gotcha. Honestly, I would start at the junkyard. You will def save some money and a good flush before install would be good enough I would think.
  5. #5 Re: 04 Fuel Line
    Pennsylvania, USA
    If you find some decent lines in a junk yard, I'd advise repainting or resealing them in some way before install to ensure you don't have to do it twice. Definitely flush the line out as stated by luckyg, don't know what may be in those lines if they've been sitting empty.
    Worst case scenario, make your own fuel lines. It's not much more difficult than making brake lines. IMO, the hardest part either way is just removal and installation, since you gotta wiggle it in at strange angles.
  6. #6 Re: 04 Fuel Line
    Dec 2012
    Maryland
    Thanks!
    "since you gotta wiggle it in at strange angles. " LOL reminds me of someone I used to know!
  1. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
  2. Fuel line leak at fuel rail
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2013, 12:43 PM
  3. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
