Thread: '05 GT2 Brake light
Results 1 to 2 of 2
  1. #1 '05 GT2 Brake light
    Aug 2012
    DC
    Im trying to figure out what bulb I need for my GP.
    Its bulb in the 'bigger' tailight section - I think there are 2 if not 3 lights in the rear assembly?
    When my car is started with key in ignition the big section of the rear red assembly is not lit(this would be in the lower brightness setting) - however when I remote start my car the rear section is fully lit which is in the higher brightness setting(brakes being set).
    Anyhow - is there 1 or 2 lights in the big part of the rear tailight assembly - or just 1?
    Also, how hard is it to replace one of those bulbs? Do I need to go through the trunk?
  2. #2 Re: '05 GT2 Brake light
    Aug 2012
    DC
    Found this info somewhere else:
    Those bulbs all will be #3057. Just pick up a pack of clear ones from Wal-Mart. To change them just pop the trunk. Pull back the carpet. Undo 3 twist nuts then pull the assembly out, change the bulb and put it all back together.
    And there are 3 different bulbs in the assembly. You will be able to see which one is bad by a black tint to the bulb
  1. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  2. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  3. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  4. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  5. Third Brake Light & LED's
    By Metallistar in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2009, 11:06 PM
