Thread: Halo Projector headlights
Page 4 of 4 FirstFirst ... 234
Results 61 to 79 of 79
  1. #61 Re: Halo Projector headlights
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Hey guys, I installed a relay kit but I am still getting some flickering. Could it be a bad battery?
  2. #62 Re: Halo Projector headlights
    I live here. DirtDog's Avatar
    Jun 2012
    How many cca's is hr battery...how old...is it a deep cycle
  3. #63 Re: Halo Projector headlights
    Oct 2012
    Illinois
    All I can see is it a 800 cca and cannot see anything with a date besides next to the serial number it says 12 05 but it looks like it is part of the label not stamped on. It is a triple A battery and has a 3 year warranty.
    Quote Originally Posted by marines542 View Post
  4. #64 Re: Halo Projector headlights
    Jun 2012
    Quote Originally Posted by smitz327 View Post
    Also if the vehicle is running they shouldn't do it cause most alternators put out between 13-15 volts which is more than enough power. Are ur ballasts 35 watt or 55
  5. #65 Re: Halo Projector headlights
    Oct 2012
    Illinois
    They are 35 watt, I also got battery checked and it has 700 cranking amps and voltage is a little below normal at 12.2, the guy said it needs charged even after driving it for 20 miles. The alternator is good.
  6. #66 Re: Halo Projector headlights
    Oct 2012
    Illinois
    I figured out the problem. After taking a drive out last night. I noticed a little flickering still going on and come to think that maybe the HID's are lose in the projector headlight itself. The housing is firm and I am positive that they do not bounce so there was only one thing left. The projectors I have are not a good fit for the bulbs but I made some modifications. In the projector light there is a slot that is meant for the filament but did not get cut all the way through. I had to file that groove all the way through then I had to make modifications to the HID's themselves. First I filed down the nipples on the plastic piece, then I had to cut some of the plastic off then it was a perfect tight fit. I tested and all is good now. I don't notice any beams crossing anymore and I get full light coverage to each side.
  7. #67 Re: Halo Projector headlights
    Oct 2012
    Illinois
    Here is a good video of what I had to do https://www.youtube.com/watch?v=-tb2uZd9yc8
  8. #68 Re: Halo Projector headlights
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    Good job on the fix, how does the light output look on em?
    2007 Pontiac Grand Prix Base - Sold
    2007 Chrysler Aspen 4.7 - Current Car/Family SUV
  9. #69 Re: Halo Projector headlights
    Oct 2012
    Illinois
    Excellent now, before it didn't look good at all. I will definitely get some photos in the next couple of days and post them
  10. #70 Re: Halo Projector headlights
    Mar 2013
    Philadelphia
    I am considering getting these as well. My stock headlights are garbage and I think a retrofit is too large of a task for me. Overall, how was your experience with these headlights?
  11. #71 Re: Halo Projector headlights
    Jan 2012
    Anaheim, Ca
    Hey it you can get a pic of how it looks from the drivers seat and on the wall too the pattern
  12. #72 Re: Halo Projector headlights
    Oct 2012
    Illinois
    Lights went in pretty easy, look over the threads on here to get install advice and also uTube. There is a little cut off but not bad at all and the quality is good compared to others. I think they look sharp. Any install questions feel free to ask
    Quote Originally Posted by TNTtransam View Post
  13. #73 Re: Halo Projector headlights
    Oct 2012
    Illinois
    Photos are not the best and lights still need some adjustments
  14. #74 Re: Halo Projector headlights
    Oct 2012
    Illinois
  15. #75 Re: Halo Projector headlights
    Jan 2012
    Anaheim, Ca
    Still looks pretty good, and goes pretty far out.
  16. #76 Re: Halo Projector headlights
    Oct 2012
    Illinois
    Yes the light goes out pretty far but adjustments need to be made like both lights are a tad low and I need to raise them just enough without blinding on coming. I like them allot and plan on buying for my red pontaic after vacation. Leaving this week for Aruba for 8 days
  17. #77 Re: Halo Projector headlights
    Jan 2012
    Anaheim, Ca
    Ya if you raise em up a little they should give you great output up to a certain distance. Have fun on your trip.
  18. #78 Re: Halo Projector headlights
    Oct 2012
    Illinois
    Thanks, just arrived today. Been very busy. Going to get another set for my red Grand Prix later. The lights on there now, cannot upgrade to HID and the light output sucks
  19. #79 Re: Halo Projector headlights
    Oct 2012
    Illinois
    I also did, but it started chattering which is very annoying. I ended up cutting the headlight flash on the DRL module which also disables the headlights from coming on at ight
    Quote Originally Posted by fisher580 View Post
    mine, a 2001 I had to unhook the heat sink under the drivers side a-piller. I still have auto's and I have the halos wired to +12v switched so there come on with the key
  1. Can HID kits fit in halo projector headlights?
    By sLpGPGT in forum Visual/Body Modifications
    Last Post: 03-31-2012, 10:55 PM
  2. Led halo projector headlights
    By Mad GTP in forum Visual/Body Modifications
    Last Post: 02-20-2012, 06:19 PM
  3. help with wiring halo projector headlights
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 04-29-2011, 10:52 AM
  4. Halo Projector Headlights + LEDs
    By 2000superGrandPrix in forum Visual/Body Modifications
    Last Post: 04-04-2011, 05:06 PM
