Thread: Reptiles improved IAT sensor!!
Results 1 to 2 of 2
  1. #1 Reptiles improved IAT sensor!!
    Donating Users chico's Avatar
    Well I've had this installed for a while and it is a great product,for anyone running the ZZP SS M-90 kit this is a must as you know this kit has a small glitch on cold startup this completely cured this problem ,it has also improved the general running of my car no more nasty gurgling intake when cold and just quicker responces to changes,good buy for $30 you'll be impressed.Chico.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  2. #2 Re: Reptiles improved IAT sensor!!
    Bastard Reptile's Avatar
    Kansas City, MO
  1. Is it possible to run without an O2 sensor?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 06-19-2008, 11:45 AM
  2. L67 MAF Sensor
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 06:00 PM
  3. MAF Sensor
    Last Post: 06-13-2008, 02:57 AM
