Thread: Harmonic balancer puller
Results 1 to 8 of 8
  1. #1 Harmonic balancer puller
    Apr 2009
    stockton ca
    ive seen a few people asking about these and what you need to pull the harmonic balancer from our cars
    ZZPERFORMANCE.COM
    has them with a few options
    never noticed they had them before
    https://www.zzperformance.com/grand_...=339&catid=111
  2. #2 Re: Harmonic balancer puller
    SE Level Member Dragon1972's Avatar
    #3-1/4by28 bolts approx. 1 1/2" long and a standard harmonic balancer puller. 24mm socket and impact wrench to remove crank bolt and also a sold metal rod appro. 1 1/2 long to pit into crankshaft threaded hole to push against and a small magnet to retrieve rod after pulling off. Torque wrench or torque stick to properly tighten crank bolt to 100ft/lbs when installing.
    Master Certified Automobile Technician
    1997 GP GT-SC
  3. #3 Re: Harmonic balancer puller
    SE Level Member quadracer960's Avatar
    indiana
    You can just go to autozone and get it for free for as long as you want. Its $15 but you get your money back when you return it. Just make sure you get the 3" long 1/4 28 bolt at an ace hardware store. the 2 1/2 seemed a little to short.
  4. #4 Re: Harmonic balancer puller
    crank bolt is SAE, not metric. 15/16'' socket head
    I have the bolts and spacer from ZZP and have used it with my standard puller kit, works well. Just make sure the bolts are fully seated. Use some oil or a wire brush to clean up the threads.
    Torque spec for the crank bolt is 111 ft lbs + 76* as per: http://www.grandprixforums.net/torqu...ifications.php
  5. #5 Re: Harmonic balancer puller
    Kansas
    We just put washers on the bolts to make them longer and the balancer came off easy. Rented from oriellys
    SOLD 1999 GT Silvermist TS
  6. #6 Re: Harmonic balancer puller
    Troy OH
    i straight up used a hammer. nobody mentioned the different bolts part, and i messed around with it until i was pissed enough to find the biggest hammer i could and beat on it for about 10 minutes. it came off. there's a thread about it here somewhere.
  7. #7 Re: Harmonic balancer puller
    so if you chuck a bearing you know why...
  8. #8 Re: Harmonic balancer puller
    Troy OH
    as long as you learn from your very expensive mistakes haha. its looks true still, i'll trust it lol
  1. How do you get the crank pulley/harmonic balancer off???
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 11:08 PM
  2. Harmonic balancer question
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 04:52 PM
  3. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
  4. Any advice removing old harmonic balancer?
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-09-2009, 06:35 PM
