Thread: Fog lights
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: Fog lights
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    if they are just hazed and yellow trying cleaning them up there are a few write-ups on how to do that in the how to section
  2. #42 Re: Fog lights
    SE Level Member mtz956's Avatar
    browntown
    the headlamps are not that bad, i think my lights are just to weak. by the way nice gtp, i have a green one.(98)
  3. #43 Re: Fog lights
    St. Louis
    thanks, i try to keep her as clean and fresh looking as i can.. well there are a few things that you can do 1. invest in a ALT. Rewire (or just make your own) it will actually make your headlights a bit bright, 2.also try getting some different bulbs i currently use sliverstars and i don't have any complaints yet
  4. #44 Re: Fog lights
    St. Louis
    or jsut pick yourself up some of these they are pricey but in reality they are priced very low, the item has ended up if you search agian they will pop up
    1997 1998 1999 2000-2003 GRAND PRIX HALO HEADLIGHTS+HID:eBay Motors (item 140317856919 end time May-05-09 11:07:51 PDT)
  5. #45 Re: Fog lights
    browntown
    last week i went to autozone to check my batt, it was ok. they told me i had a weak ATL charge. maybe it is da ATL!
  6. #46 Re: Fog lights
    St. Louis
    could be do you know how many volts it is pumping out?
  7. #47 Re: Fog lights
    browntown
    DO u mean the hid's da bulb or da headlamps? i think it was below 13. and yeah i have some silverstars too! i chaged them thinking it was the old bulbs da problem.
  8. #48 Re: Fog lights
    Topeka, KS
    I don't run my headlights without the fogs. It's like running two mag lights out the side of the window with out them. Autopia Fogs for the win! Best mod i've ever done hands down.
  9. #49 Re: Fog lights
    GT Level Member Dohner's Avatar
    Montpelier
    Quote Originally Posted by stlmo_gtp View Post
    Hey man how do you make your own ALT Rewire?? I would really like to try this if it is something I can do with rather ease.
  10. #50 Re: Fog lights
    Topeka, KS
    This is all i did... And was told how to do it. Go to Wal-mart and get a battery cable that already has the ends on it. I'm not sure how much they are... Attach one end to the bolt on the top of the fuse box and the other end to the alt. Make sure you have your ground disconnected when you do this.
    ZZP or Casper's make kits that are alot better than this too but it seems to help.
    Here's one for sale on CGP.
    http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
  11. #51 Re: Fog lights
    Montpelier
    That is all you have to do? Thats great i am going to have to try this. Is there any down side to this i mean is there a way that i could screw this up or something up on the car.
  12. #52 Re: Fog lights
    St. Louis
    no you can't really mess it up just be sure to have the ground on the battery disconnected
  13. #53 Re: Fog lights
    Montpelier
    I will have to try that sometime here. NOw will this help with the lights dimming with the bass and everything to. Or do you know how much more voltage you got by doing this?
  1. HID lights
    By mzendano in forum Visual/Body Modifications
    Last Post: 12-22-2008, 02:25 PM
  2. Fog Lights
    By xbnb1978x in forum Visual/Body Modifications
    Last Post: 08-24-2008, 02:54 PM
  3. cop lights
    By Tyler_06 in forum Visual/Body Modifications
    Last Post: 07-04-2008, 05:05 PM
  4. ABS and TCS Off lights are on
    By 03GTPFour in forum General Tech Discussion
    Last Post: 04-23-2008, 10:10 AM
