if they are just hazed and yellow trying cleaning them up there are a few write-ups on how to do that in the how to section
thanks, i try to keep her as clean and fresh looking as i can.. well there are a few things that you can do 1. invest in a ALT. Rewire (or just make your own) it will actually make your headlights a bit bright, 2.also try getting some different bulbs i currently use sliverstars and i don't have any complaints yet
or jsut pick yourself up some of these they are pricey but in reality they are priced very low, the item has ended up if you search agian they will pop up
1997 1998 1999 2000-2003 GRAND PRIX HALO HEADLIGHTS+HID:eBay Motors (item 140317856919 end time May-05-09 11:07:51 PDT)
I don't run my headlights without the fogs. It's like running two mag lights out the side of the window with out them. Autopia Fogs for the win! Best mod i've ever done hands down.
This is all i did... And was told how to do it. Go to Wal-mart and get a battery cable that already has the ends on it. I'm not sure how much they are... Attach one end to the bolt on the top of the fuse box and the other end to the alt. Make sure you have your ground disconnected when you do this.
ZZP or Casper's make kits that are alot better than this too but it seems to help.
Here's one for sale on CGP.
http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
That is all you have to do? Thats great i am going to have to try this. Is there any down side to this i mean is there a way that i could screw this up or something up on the car.
I will have to try that sometime here. NOw will this help with the lights dimming with the bass and everything to. Or do you know how much more voltage you got by doing this?
