Thread: Transmission wont downshift works manually???
Results 1 to 6 of 6
  1. #1 Transmission wont downshift works manually???
    Michigan
    Hello guys Im working on a 1994 buick regal with the 3800, Transmission operates fine if you ease into it but if you punch 50 percent or more throttal it it seams to jump into third or forth and stay there unless you manually shift it. transmission is newer 50k on it and has had a recent fluid change car has 230k miles on it any ideas what would be causing it not to downshift?
    Iv been doing research all day and haven't found anything no check engine nothing just wont shift in auto any ideas would be appreciated.
  2. #2 Re: Transmission wont downshift works manually???
    Do you know if that is the 4T60 or 4t440?
  3. #3 Re: Transmission wont downshift works manually???
    Michigan
    I am not sure where could I find out
  4. #4 Re: Transmission wont downshift works manually???
    I googled it. Looks like a 4T60. Definatley not the average problem you are having. How is the motor running? MAF/MAP and TPS play a big part in the shifting.
  5. #5 Re: Transmission wont downshift works manually???
    Apr 2016
    Pittsburgh
    I have a '95 grand prix and my trans was doing the same exact thing. It has a 4T60-E trans but when I tore it apart and had it looked at it turned out that the trans was shot. The torque converter had a large amount of clutch material in it and the final drive gear was sheared. I am currently replacing the transmission. I bought a new one at a junkyard and then had it rebuilt. Hope this helps
  6. #6 Re: Transmission wont downshift works manually???
    Cleveland Heights, Ohio, United States
    If you need one, I have a rebuilt one for sale. 44118 area
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  1. Replies: 7
    Last Post: 04-24-2013, 11:46 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. Transmission Can Only Be Shifted Manually
    By devinpitcher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2011, 12:31 AM
  4. tranny wont downshift
    By copperpacecar in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-19-2010, 12:26 PM
  5. Auto transmission only shifting manually
    By jordya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 10:42 AM
