I have a 96 GP SE, it has the 3.1 and 4 spd auto, the problem I am having is the trans will start shifting eratic , mostly once it gets warm and it feels like it is shifting to soon, unless you put your foot in it ! But when you are just driving around town it kinda lobs into the gears. From what I have read on the car and talked to people I was told to first change the fluids and filter, that didn't help so I changed the modulater on the front of the trans, seemed to get a little better, but now is getting worse again, I was told now to try putting a control solinoid in the trans, I bought it but have no idea where it is located to change it, I have read some info on it that just said it was hard to get to and that you have to get to it from a side access plate behind a K-brace that must be removed, is this on the drivers side of the motor, and would I be able to get to it via the wheel well if I removed the driver side front wheel? If it is, what is the best way to get at it, or am I looking in the wrong place. any help on this would be great. LB
