Thread: 96 Grand Prix SE taking off in high gear when hot
Results 1 to 4 of 4
  1. #1 96 Grand Prix SE taking off in high gear when hot
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    So the 96 shifts great when cold and a moment after reaching operating temp it will take off in high gear 3rd maybe even 4th. It takes a lot of RPM to get the car moving. Shifting to 1st gear at a stop or moving does not help. I shut it off for a while and then it starts take off from 1st or launch from 1st.
    there is no 2nd gear launch button on this car but it does not feel like it is taking off from 2nd it feels higher. the RPM is 3K or more and the coolant starts get hotter than normal, just under overheating.
    Someone mentioned a relay or something electrical. Can someone shine some light into the potential of an electrical issue?
    TIA,
    Nick
    Chicago
  2. #2 Re: 96 Grand Prix SE taking off in high gear when hot
    new britain, ct
    maybe its a bad clogged cat. how many miles are on your car, and when was the last tune up done to it?
    07 Black GXP.
  3. #3 Re: 96 Grand Prix SE taking off in high gear when hot
    Apr 2008
    Chicago, IL
    Shift fine cold.
  4. #4 Re: 96 Grand Prix SE taking off in high gear when hot
    SE Level Member Undercrazed's Avatar
    Sc
    I had a very similar issue with mine which was just recently fixed. On my 96, it was the tcc solenoid. However I was gettin cel codes for shift solenoids 1 and 2. When I got in there two of the 3 identical solenoids were cracked and the tcc's electrical plug fell off in my hand. Could be the same problem with yours. I did the work myself if you need some info on how to do it. It's fairly easy just takes a while. Is your cel light on? If so get it checked. It could very well tell you what's wrong like mine did.
    96 Gp Se - Stock - 215k and running stronger than ever
    Much work to come
  1. Problems taking off, shudders and clunks into gear
    By Eddie Jackson in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2012, 12:20 PM
  2. Grand Prix 07 High Miles
    By steelholder in forum General Tech Discussion
    Last Post: 04-21-2011, 08:33 PM
  3. Grand prix issue w/gear i think
    By Vette Zr1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2011, 07:08 PM
  4. 01 grand prix 3.8 gt not going into 4th gear at all
    By wiredup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-18-2010, 01:23 PM
