Thread: 95 GP Shifting problem
Results 1 to 3 of 3
  1. #1 95 GP Shifting problem
    PA
    Starting out the tranny won't shift out of 1st gear till I let off the throttle or till it is almost on rev limiter. I replaced the vacuum mod no change. Any help would be appreciated.
    Thanks
    DaveB
  2. #2 Re: 95 GP Shifting problem
    If you replaced the modulator, then you likely ensured the vacuum line to it was good as well?
  3. #3 Re: 95 GP Shifting problem
    PA
    Yes I checked the vacuum lines they are ok. The problem is intermittent so it is possibly a valve sticking. I'm going to try some Lucas and see if that helps.
    Thanks
    Dave
  1. 4T60E shifting problem
    By wrpfctr7 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 01-21-2014, 08:02 PM
  2. from 3rd or 2nd to 1st slipping shifting problem
    By RyanL in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-16-2010, 12:54 PM
  3. Shifting Problem
    By taximech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2010, 07:06 AM
  4. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  5. Shifting problem, pls help
    By mtrmes02 in forum General Tech Discussion
    Last Post: 01-23-2010, 09:07 PM
