Thread: 1997 4T60E side cover gasket
Results 1 to 4 of 4
  1. #1 1997 4T60E side cover gasket
    Jun 2010
    Illinois
    Took the side cover off of my 1997 GP to replace the solenoids and bent the steel/rubber gasket that came off the side cover. Did'nt know it could be reused so I tossed it. Now I gotta get a new gasket and found out that there's a few options I gotta go over.
    1. The OEM gasket is for the aluminum side cover and it's a steel and molder rubber gasket that I found goes for between $80-$120 bucks.
    2. There's a cork style gasket that fits the cover and it runs about 30 bucks.
    3. AutoZone and Advance Auto (on thier websites) along with other Transmission places show a steel/rubber gasket that states it will fit the 4T60E AND the 4T65E transmissions, but it does'nt look likeit would fit.
    My question is, can I go with the cork gasket to save some cash or should I pony up and get the steel/rubber gasket. Also, will that other gasket made for the 4T65E fit my side cover?
    Any help would be appreciated!!!
  2. #2 Re: 1997 4T60E side cover gasket
    Charles City, IA
    rubber and steel the cork will leak.
    SMGPFC Two Nipple General
  3. #3 Re: 1997 4T60E side cover gasket
    St. Louis
    Check RockAuto. They'd be likely to have AC Delco gaskets at a reasonable price. May even show a pic of it so you can be sure it's the correct one.
  4. #4 Re: 1997 4T60E side cover gasket
    Jun 2010
    Illinois
    Yeah, I checked Rock Auto and the picture that they show looks different from the gasket that I need. It also states that it is the 2nd design. Since I know the gasket is reuseable, I might go to my favorite junk yard and see if I can find one.
  1. 4t65e side cover gasket $29.99 Advance auto
    By davevanoke in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-25-2013, 03:24 PM
  2. 1997 2nd design 4T60E Trans pan gasket
    By Pauley in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-01-2011, 07:06 AM
  3. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
  4. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
