Thread: What parts will i need ??
Results 1 to 2 of 2
  1. #1 What parts will i need ??
    GXP Level Member ryangtp89's Avatar
    Maine
    So my tranny is ready to go but thats ok cause i have another car and i am storing it in my garage for the fall/winter and i plan on taking the tranny out and i want to run the car this summer soo ill need to rebuild the tranny. It has 157k on it. Now the most i plan on going with my car is 2.8 at the verry most with supporting mods and i want a tranny that will hold up to that, soo what parts will i need ?? Hardened 4th clutch shaft, trq conveter etc. ???
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: What parts will i need ??
    TDCRacing
    Guest
    Well of the bat stock remanned converter will be fine as they tend to stall aronf 2900 anyway.Go with a hardend 4th clutch hub.Will you be running slicks? If so you may want to invest in an intense hardend input shaft. And I would go with a 7/8's chain also along with replacing all the seals gaskets ect in a normal rebuild. And what ever gears you decide to go with if your switching ratio's.
    So my mod list and yours may have something in common? FWIW I am very happy with my car now and the way it performs. And something i can finially say is i think im almost done with it. Almost ??
  1. Looking for parts
    By TurboKent in forum Turbo
    Last Post: 08-10-2009, 01:08 AM
  2. 97 GT parts
    By jmak gtx2 in forum Southeast
    Last Post: 05-10-2008, 10:04 AM
