Hello,
The transmission in my Grand Prix will not shift into drive after sitting overnight. It will finally go into drive after the engine has been running for a minute or two. I'm not sure if revving the engine or changing gears makes a difference. The transmission shifts fine while driving and will even shift into drive if the car has only been sitting for a few hours.
I checked the fluid and it was a little low, but filling it did not make a difference. Does anyone have any ideas as to what could be causing the problem? Will it be an easy fix or an expensive rebuild?
TIA,
Brandon
