Thread: Transmission won't shift into drive after sitting overnight
Results 1 to 4 of 4
  1. #1 Transmission won't shift into drive after sitting overnight
    Canada
    Hello,
    The transmission in my Grand Prix will not shift into drive after sitting overnight. It will finally go into drive after the engine has been running for a minute or two. I'm not sure if revving the engine or changing gears makes a difference. The transmission shifts fine while driving and will even shift into drive if the car has only been sitting for a few hours.
    I checked the fluid and it was a little low, but filling it did not make a difference. Does anyone have any ideas as to what could be causing the problem? Will it be an easy fix or an expensive rebuild?
    TIA,
    Brandon
  2. #2 Re: Transmission won't shift into drive after sitting overnight
    Jul 2008
    sumter,south carolina
    will it go in first, second, third manually on cold start?
    02 GTP with mods 05 GP for DD
  3. #3 Re: Transmission won't shift into drive after sitting overnight
    Canada
    If I put the stick on 1, 2, 3, R, or D I get the same results.
  4. #4 Re: Transmission won't shift into drive after sitting overnight
    Canada
    It also only happens when the car is parked with the front end on the low portion of a slope.
  1. Transmission will not shift into overdrive
    By JennysGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2012, 10:37 PM
  2. Transmission is slipping in drive
    By KarenC in forum General Tech Discussion
    Last Post: 06-01-2011, 03:22 PM
  3. Transmission wont shift out of 1st
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-22-2010, 08:42 PM
  4. Tap Shift Transmission.
    By isucyclones3 in forum General Tech Discussion
    Last Post: 02-08-2009, 09:36 PM
  5. Transmission shift solenoid compatibility
    By BackInBlack in forum General Tech Discussion
    Last Post: 10-18-2008, 01:19 PM
