Thread: 96 gtp trans
Results 1 to 3 of 3
  1. #1 96 gtp trans
    SE Level Member cb43x's Avatar
    montevideo
    is there any difference with the 3.4 gtp trans? Will one out of a 95 3.1 work?
  2. #2 Re: 96 gtp trans
    GM did a lot of changes internally to the 4T60 over the span of it's life. My suggestion would be to use the newest possible and check the gear ratio.
    If you use a different year, make sure you swap the electrical harness inside the trans with the one on your car. they changed pinouts etc and that one thing should make it work fine.
  3. #3 Re: 96 gtp trans
    montevideo
    so what years will work in it? im not too worried about the grear ratio..
  1. What Trans?
    By TeeWX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-22-2010, 08:33 AM
  2. cant get my trans out
    By gpgtman83 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2010, 10:46 PM
  3. trans going out?
    By chuy09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2010, 10:03 PM
  4. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  5. 06 trans in a 99 gt?
    By bronzemist99GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2008, 01:52 AM
