Thread: 1993 3.1 running problems could be trans
Results 1 to 3 of 3
  1. #1 1993 3.1 running problems could be trans
    Donating Users
    phila pa
    Problems: Hi my son has 1993 grandprix 3.1 4 speed auto.the car cuts out
    and buck under load. is fine at highway speed .runs good at idile. also no
    problems in reverse. change wires coil pack plugs.scaned computer no problem
    codes everything looks good. banged the computer to see if anything is lose
    in side. wonder could it be a lock up solenoid or module or bad computer.
    any idea. also
    hi check the fuel pressure at idle it is 38 .when you shut of the car it hold at 40.when in drive with foot on brake I rev it up it goes to 42 pounds before it cuts out ,is that enough pressure.it is fine in reverse and on the highway .will change fuel filter thanks Ron.
  2. #2 Re: 1993 3.1 running problems could be trans
    Donating Users
    phila pa
    hi turn out to be the fuel filter put in a cheap wone.put in a wix car runs fine.
  3. #3 Re: 1993 3.1 running problems could be trans
    Donating Users
    phila pa
    hi it turn out to be the side crankshaft sensor pigtail.
  1. problems with car running
    By dsanchz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2009, 02:02 AM
  2. Help!!! Trans,Front End,Secondary air injection PROBLEMS!!!!!
    By 00gpgt in forum General Tech Discussion
    Last Post: 04-02-2009, 08:56 PM
  3. Running Trans oil as engine oil
    By 04CompG in forum General Tech Discussion
    Last Post: 11-25-2008, 12:09 AM
  4. Starting/running problems
    By 04gpgt2 in forum General Tech Discussion
    Last Post: 10-21-2008, 09:29 PM
  5. Trans problems.
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 07:24 AM
