Thread: 4t60e
Results 1 to 5 of 5
  1. #1 4t60e
    Pittsburgh
    Hi.
    I'm having some trouble with my 4T60E and would appreciate any help. Here's what it's doing:
    -Slips in any Gear selected, including reverse, when pulling out from a stop EXCEPT Low1. It will pull out ok if I don't give it too much gas and not on a steep grade. But will pull fine in Low1.
    -Shifts fine while underway otherwise.
    -No noticeable fluid smell or bad color.
    -Has 100K miles on it.
    -No fuses bad
    -Will eventually "lock up" and pull out if given enough gas
    -Problem getting progressively worse.
    I'm no tranny expert so I have no idea why Low1 works good while the other selected gears don't.
    Thank you in advance!
  2. #2 Re: 4t60e
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    With the info you provided it looks like you input apply clutches are burnt and not holding as well as they should, or the input apply piston is in very bad condition. This clutch applies in reverse and 1st gear and is really about the only common link between the two. In manual 1st range 3rd clutch is also applied for engine breaking and extra holding power and this is likely overcoming the slipping input clutch, that and the line pressure is quite a bit higher in manual 1st to aid in pulling up or coasting down a steep grade. There arent many other posibilities and unfortunately means rebuild.
  3. #3 Re: 4t60e
    Pittsburgh
    Thank you very much for responding.
    My first guess would have been the converter is going bad, as I thought the converter actually applies the drive pressure?
    Also, and this will probably sound pretty strange, but when you mentioned line pressure I immediately thought of some way to increase the pressure without disassembly i.e. an external pump installed between the cooling lines to the radiator. In theory, could an external pump (like maybe a fuel pump) actually help? A fuel pump would be inexpensive, easily mountable under the hood, probably applies roughly the pressure needed, and is designed to run a similar chemical.
    I only paid 1K for the car and would be happy to get another year out of it before buying something else.
  4. #4 Re: 4t60e
    Pittsburgh
    *Update*
    I checked the error codes and got an E.96 "Torque Converter Overstress"
  5. #5 Re: 4t60e
    Pittsburgh
    Anyone?
  1. 4t60E and 4t65E case ???
    By 16MustangVet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-17-2009, 10:47 PM
  2. Will a 4T65E got in a 97 car in place of a 4T60E?
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-24-2009, 05:23 PM
  3. need help with 4t60e
    By ez35 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 09-05-2008, 03:28 PM
  4. Help with 4T60E
    By rockthunder in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-23-2008, 01:11 AM
