Thread: PCM help
Results 1 to 6 of 6
  1. #1 PCM help
    Donating User
    Jul 2014
    Minnesota
    I am new to PCM stuff and I am looking into purchasing a tuned one and my question is, when installing it, is it as simple as just unplugging the old one and plugging in the new one and away you go?
    If not, please enlighten me.
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: PCM help
    yup, only un hook the battery first. then swap the pcm.
  3. #3 Re: PCM help
    Worst case scenario is you have to do a key relearn procedure which takes 30 min and requires no special tools.
  4. #4 Re: PCM help
    GT Level Member mguzzo's Avatar
    Buffalo NY
    and a crankshaft position relearn ("CASE learn") is recommended when you swap a PCM into a car for the first time, and required if the MIL gets set for P1336 code.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: PCM help
    Donating User
    Jul 2014
    Minnesota
    ok thank you. I currently just have an intake installed but I plan to get a downpipe with u bend delete, is there a noticeable difference with the upgraded PCM?
  6. #6 Re: PCM help
    Bastard Reptile's Avatar
    Kansas City, MO
    Yes....always a noticeable difference. Yes on the case relearn...rarely the key has to be relearned. And you don't necessarily have to unhook the battery, I never have. Doesn't mean you don't have to though.
