Thread: Help with PCM
Results 1 to 20 of 34
  1. #1 Help with PCM
    Chicago, IL
    I was looking at getting the digital hp PCM from pfyc.com. I was wondering what is a security relearn and would all the instructions on how to do that be included when I purchase it? Secondly what is a core charge. I am learning so any help would be great thanks.
  2. #2 Re: Help with PCM
    Barksdale AFB, LA
    First, don't bother with their PCM. Get one from Will at Overkill.
    Second, the security relearn is part of your car's security system. The PCM has to learn itself to your car. The instructions are right here:
    http://www.cartuning.ca/images/white...0Procedure.pdf
    A core charge is what you pay for the part that they're sending you. In the case of a PCM, the core charge pays for the physical PCM they send you. The rest of the money pays for their work on the programming in the PCM. When you get the PCM, and send back your old one, they give you the core charge back. It's kinda like a deposit. If you don't want to send yours back, you just bought the physical PCM at their cost. The only way around a core charge is to send yours in first.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Help with PCM
    Chicago, IL
    Is it pretty easy to take out the old pcm and put in a new one? Why is the one from Will at Overkill better?
  4. #4 Re: Help with PCM
    Barksdale AFB, LA
    Quote Originally Posted by 04gpking85 View Post
    Because will knows more about tuning. Also, his will be custom tailored to your car and your mods, not just a generic PCM for all cars.
  5. #5 Re: Help with PCM
    Jul 2008
    sumter,south carolina
    cuz hes the man lol...if u can change an air filter u can change pcm...nobody on this site will steer u in the wrong direction...ive heard nothing but excellent stuff about wills pcm's
    02 GTP with mods 05 GP for DD
  6. #6 Re: Help with PCM
    Chicago, IL
    Is the overkill site :: Overkill Motorsports ::
  7. #7 Re: Help with PCM
    Barksdale AFB, LA
    Yes.
  8. #8 Re: Help with PCM
    Jul 2008
    the pcm link on overkill site was down earlier today...good luck gettin what u need.
  9. #9 Re: Help with PCM
    Jersey
    Defintily go with overkill, will helped me beat some 3.5 maximas
    16' wrx sti- stock
  10. #10 Re: Help with PCM
    Chicago, IL
    I see I see, is there a case relearn as well? I'm guessing CA is Canada? How much would the PCM be in USD?
  11. #11 Re: Help with PCM
    Jersey
    u shouldnt need a case relearn, Will said that u only need a case relearn if you get a check engine light. A well spent $170 thats including the core charge. I wanted to keep my old one for when i go turbo or s/c. I forget what shipping was but it took a while. About 2 weeks for me.
    16' wrx sti- stock
  12. #12 Re: Help with PCM
    SE Level Member hotshot's Avatar
    R.I.
    Quote Originally Posted by 99prixgt View Post
    I always thought you needed a case learn on any 98+ cars unless you were putting the same pcm back in. I read this on the intense racing forum.
    "The crankshaft position system variation learning feature calculates the reference period errors that are caused by slight tolerance variations in the crankshaft, the crankshaft balancer interrupter rings, and the crankshaft position sensor hall effect switches. The calculated error allows the PCM to accurately compensate for reference period variations. This enhances the ability of the PCM to detect misfire events during a wider range of engine speed and load conditions.
    The crankshaft position system variation values are stored in the PCM non-volatile memory after a learn procedure has been performed. If the crankshaft position system variation values are not stored in the PCM, DTC P1336 will set. The learn procedure is required after the following service procedures have been performed:
    PCM replacement
    Engine replacement
    Crankshaft replacement
    Crankshaft balancer replacement
    Crankshaft position sensor replacement
    Any engine repair which disturbs the crankshaft or the harmonic balancer to crankshaft position sensor relationship. "
    "You DO need to perform the Crankshaft Variation Learn procedure if you physically install a new PCM, replace the crankshaft, camshaft, timing chain, crankshaft position sensor or balancer.
    You DO NOT need to perform the Crankshaft Variation Learn procedure if you have new code flashed into your current PCM."
    Not trying to contradict you bro just trying to put out as much info as I have on the subject. The only reason i havn't got a pcm yet is because I don't want to have to get a case learn every time I step up the modding or be without the car if I send the one I have in it out. I could be wrong but I just want to throw what i read out there, I have always had awesome luck with INTENSE.
    98 GTP - slp powerflo cat back, built tranny, AP104s, homemade FWI and intense 180 stat.
  13. #13 Re: Help with PCM
    Chicago, IL
    Ok well this is a really dumb question but where is the PCM located?
  14. #14 Re: Help with PCM
    Barksdale AFB, LA
    In the bottom of the airbox.
  15. #15 Re: Help with PCM
    Chicago, IL
    Quote Originally Posted by Sabrewings View Post
    There's three of them under the airbox, which one is it?
  16. #16 Re: Help with PCM
    TDCRacing
    Guest
    Fail ...There is only one pcm in the airbox. There is only one thing in the air box that looks like a pcm
  17. #17 Re: Help with PCM
    Oct 2008
    Idaho
    I've got a bone stock '02 GTP. Would this be a good first mod to get or should I hold off until I get CAI, U-bend & exhaust? The intake and exhaust stuff is about a year off. I'm curious if I would see any gains with a PCM upgrade on a stock car and whether it's worth it.
    Thanks,
    Tim
  18. #18 Re: Help with PCM
    Barksdale AFB, LA
    PCM should not be your first mod.
  19. #19 Re: Help with PCM
    Banned
    Wichita Falls, Texas
    See the dark blue thing underneath the red arrow? Thats your PCM, it won't be blue, it will be a ugly metallic color, bunch of wires going to it.
  20. #20 Re: Help with PCM
    Banned
pcm
