Thread: which ifr is right?
Results 1 to 20 of 35
SgtMarshal which ifr is right? 05-21-2015, 10:22 AM
Iceman6669 Re: which ifr is right? 05-21-2015, 03:34 PM
bandook Re: which ifr is right? 05-21-2015, 04:41 PM
Iceman6669 Re: which ifr is right? 05-21-2015, 04:45 PM
SgtMarshal Re: which ifr is right? 05-22-2015, 07:50 AM
timboku Re: which ifr is right? 05-22-2015, 08:20 AM
SgtMarshal Re: which ifr is right? 05-22-2015, 09:54 AM
BillBoost37 Re: which ifr is right? 05-22-2015, 09:58 AM
bandook Re: which ifr is right? 05-22-2015, 10:03 AM
SgtMarshal Re: which ifr is right? 05-22-2015, 10:08 AM
timboku Re: which ifr is right? 05-22-2015, 11:41 AM
bandook Re: which ifr is right? 05-22-2015, 12:26 PM
SgtMarshal Re: which ifr is right? 05-22-2015, 01:45 PM
Iceman6669 Re: which ifr is right? 05-22-2015, 02:42 PM
SgtMarshal Re: which ifr is right? 05-22-2015, 03:03 PM
Iceman6669 Re: which ifr is right? 05-22-2015, 03:04 PM
SgtMarshal Re: which ifr is right? 05-22-2015, 03:13 PM
SgtMarshal Re: which ifr is right? 05-24-2015, 09:50 PM
bandook Re: which ifr is right? 05-25-2015, 10:19 PM
NebTurboST5 Re: which ifr is right? 05-25-2015, 06:17 PM
SgtMarshal Re: which ifr is right? 05-25-2015, 07:34 PM
NebTurboST5 Re: which ifr is right? 05-25-2015, 09:33 PM
SgtMarshal Re: which ifr is right? 05-25-2015, 10:31 PM
bandook Re: which ifr is right? 05-25-2015, 10:36 PM
SgtMarshal Re: which ifr is right? 05-26-2015, 04:00 PM
SgtMarshal Re: which ifr is right? 05-27-2015, 07:21 AM
bandook Re: which ifr is right? 05-28-2015, 02:39 PM
SgtMarshal Re: which ifr is right? 05-28-2015, 10:02 AM
NebTurboST5 Re: which ifr is right? 05-28-2015, 04:34 PM
SgtMarshal Re: which ifr is right? 05-28-2015, 04:56 PM
SgtMarshal Re: which ifr is right? 05-28-2015, 08:40 PM
SgtMarshal Re: which ifr is right? 05-28-2015, 03:51 PM
bandook Re: which ifr is right? 05-28-2015, 04:00 PM
SgtMarshal Re: which ifr is right? 05-28-2015, 04:18 PM
NebTurboST5 Re: which ifr is right? 05-28-2015, 04:35 PM
  1. #1 which ifr is right?
    Kemmerer, Wyoming
    it might seem like a dumb question, but which one is better for 42.5 lb injectors? my fuel trims have been rich for the past month, and I'm trying to figure out if my ifr is the cause.
    which ifr is right? Attached Images
  2. #2 Re: which ifr is right?
    The Boss Iceman6669's Avatar
    Jun 2011
    Try the one on the left and reset the trims. See if that does any good.
    2011 F-150 Yote powered
  3. #3 Re: which ifr is right?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by Iceman6669 View Post
    I'm total noob to tuning. Can you explain why you would choose the table with higher values? My initial thought was the smaller values, since he's running rich.
    Also, couldn't you lean it out by decreasing MAF table values?
    Top Swapped 01 Imp
  4. #4 Re: which ifr is right?
    Jun 2011
    Lol. I meant the one on the right. Mis-typed
  5. #5 Re: which ifr is right?
    Kemmerer, Wyoming
    I loaded the one on the right, and reset the trims, and its still running rich. I'm wondering if the rich condition fouled my spark plugs, and or my o2 sensors. I have the autolite 103's in now, thinking about changing them back to the 104's to see if it makes a difference.
    the race track is open tomorrow if it doesn't rain, so I'm hoping to get this figured out today and run it at the 1/8 mile. I even reset the tune to one of my very early tunes to see if there was something else in the tune that could be causing the richness. and still did the same thing.
  6. #6 Re: which ifr is right?
    Donating Users timboku's Avatar
    Montgomery, IL
    How rich are you? Why don't you just adjust maf tables where you are rich? Tuning with a nstar tb was a b$#*@ for me as well...I imported 42.5 ifr, got trims within 7ish, then adjusted maf accordingly, and fine tuned with table modifier thingy...took forever but it worked out.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  7. #7 Re: which ifr is right?
    Kemmerer, Wyoming
    if it was only 7ish I would do that, but its around -22
  8. #8 Re: which ifr is right?
    There's too many variables that you leave out if you only look at IFR.
    To that point though, you can scale your injectors down by say 10% and see if that brings you into range. Maybe your fuel pressures are right on or above average and your regulator is giving you great pressure to the injectors.
  9. #9 Re: which ifr is right?
    Apr 2015
    Columbus, OH
    Have you made sure you don't have a leaky injector? If you keep lowering your IFR but your trims don't change it seems plausible. Are trims always low or just at idle?
    Top Swapped 01 Imp
  10. #10 Re: which ifr is right?
    Kemmerer, Wyoming
    I changed out the injectors and the same thing happened. how much fuel pressure is too much? I tested it a few months ago and at idle it was reading like 53, which is 1 psi of the range listed in the book we were reading from.
    the other thing I noticed is that the rear o2 sensor range is anywhere from 0-900, which I think it is supposed to stay under 500, but I already know its running rich, so that doesn't really help.
    is there any reason the autolite 103 spark plugs could be causing the rich ltft's?
  11. #11 Re: which ifr is right?
    Montgomery, IL
    Possible vac leak? Do you have correct lq4 table in....that seems like a mechanical issue more than a tune..or a messed up 02 sensor..you running a cat?...when is it running rich idle, cruise, wot, all of them?
  12. #12 Re: which ifr is right?
    Apr 2015
    Columbus, OH
    Spark plugs would if its misfiring.
    Top Swapped 01 Imp
  13. #13 Re: which ifr is right?
    Kemmerer, Wyoming
    it runs rich all the time. I'm pretty sure its a mechanical issue because I've changed the tune several times and runs rich with no change, although my car starts easier when the IFR is leaner. I'm thinking there is too much fuel pressure, just put in a new map with no change, thought maybe too much map pressure would cause the rich condition, but the map readings are the same from several months ago.
  14. #14 Re: which ifr is right?
    Jun 2011
    what are your fuel trims under boost?
  15. #15 Re: which ifr is right?
    Kemmerer, Wyoming
    I tried to answer just "0", but it gave me a fail message for too few characters. short term goes to 0 and long term shows -0.78
  16. #16 Re: which ifr is right?
    Jun 2011
    if your LTFTs are at 0.0 under boost then I would adjust the maf curve to get the trims back on track. I would adjust the IFR to get the LTFT back to 0.0 under boost first.
  17. #17 Re: which ifr is right?
    Kemmerer, Wyoming
    I tried doing a maf smoothing with the table modifier scan data thing and it didn't seem to have any effect. I have hp tuners and am about to buy some credits to start using it on my car, do I just do a maf smooth with the hp tuner, and the fuel tables look totally different between the dhp and hpt.
  18. #18 Re: which ifr is right?
    Kemmerer, Wyoming
    Maf adjustment does nothing, thinking the fuel pressure regulator might be bad
  19. #19 Re: which ifr is right?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by SgtMarshal View Post
    Have you pulled the vav off it and seen if it leaked? I've seen them take almost 2 minutes before fuel came out.
    Top Swapped 01 Imp
  20. #20 Re: which ifr is right?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    didnt you have this pile of bolts down to like + or -7 on your ltft's a while ago? definitely gotta get it right mechanically before you start ****ing with the computer. what was the stock value of the IFR before you started messing with the tables?
    FOR ALL OF YOU CONFUSED ABOUT INJECTOR FLOW RATE VALUES...
    in DHP the IFR is measured in mSec/gram that means time to shoot a certain amount of fuel. in hptuners and most general ratings for injectors they are measured in lb/hr or cc/min meaning amount of fuel delivered in a specific time...see how these are different?
    that means that while 42.5 lb/hr injectors are larger then stockers, in DHP the number in the computer will actually get smaller because a bigger injector can deliver a given amount of fuel (in this case 1 gram) in less time then a smaller injector.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
