Thread: Interpreting scan logs, any help please?
Results 1 to 20 of 80
Threaded View
  1. #11 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by SgtMarshal View Post
    I would highly suggest the use of UVScanner instead of the dhp scanner. the dhp scanners is less effective, loses data, doesn't collect as much data, and in your case fails when you try to use your wideband. when you install the uvscanner software, I think you need to make sure you have only one version downloaded, and I have had the most luck with the newest version of the uvscanner. I have a wideband O2 sensor as well, and couldn't get it to to work with dhp software, when I started using uvscanner it just worked.
    I am using UV now, thanks! I could only get one version to work, but I see no way of adjusting my wideband sensor analog input. It reads the voltage fine, but I can't find a way to adjust the formula. Looks like different versions are supported, but not my AEM wideband. I found UV scanner v3 online just now. It has a different interface, but on my windows 8 it acts goofy. When the windows are expanded, the top half is missing and I can't move them.
    Top Swapped 01 Imp
  1. PRJ Fuel logs
    By Javi in forum Wanted To Buy - Parts
    Last Post: 02-05-2015, 11:38 AM
  2. Fuel Logs, 42.5's
    By Dtrick22 in forum Wanted To Buy - Parts
    Last Post: 02-28-2014, 01:18 PM
  3. Interpreting torque specs.
    By NinetyEightGTP in forum General Grand Prix Discussion
    Last Post: 07-04-2013, 10:05 PM
  4. WTB: Fuel Logs
    By 1999black3800 in forum Wanted To Buy - Parts
    Last Post: 03-16-2013, 09:49 AM
