Thread: Looking for a tuner in Hampton Roads area of va.
Results 1 to 10 of 10
  1. #1 Looking for a tuner in Hampton Roads area of va.
    Mar 2013
    Norfolk va
    Hey guys I have a 2003 gtp with 112,500 miles on her. Current mods are...
    Tog headers
    Downpipe with high flow cat
    SLP exhaust
    Como cams extreme energy cam.
    Will have to put specs up later..
    #130 comp springs
    Comp pushrods
    Rollmaster double timing chain
    3.4 pulley
    Canned dhp tune
    I just installed new zzp wires ported throttle body and should receive zzp's intake tomorrow..
    I have been on the same plugs for way too long and I think that's why I was getting so much knock.. Around 7 at wot.. And when I pulled the plugs they were white, all six.. Something to be concerned about? Or is this normal wear?
    Also looking for a tuner...[IMG][IMG][/IMG][/IMG]
    Sent from my SCH-I535 using Tapatalk
  2. #2 Re: Looking for a tuner in Hampton Roads area of va.
    gardner,mass
    What are you running for plugs? You are running lean. put some al 104s in there gapped at .060 and get the thing tuned via wideband.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: Looking for a tuner in Hampton Roads area of va.
    Mar 2013
    Norfolk va
    I just put NGK iridium's tr6 plugs in.. I had NGK one heat range cooler than stock for damn near 50,000 miles. On a canned tune from 3800 performance..
  4. #4 Re: Looking for a tuner in Hampton Roads area of va.
    Kemmerer, Wyoming
    http://www.compcams.com/Company/CC/c...csid=1075&sb=2
    is this the cam you are running? I like the powerband of this cam because I dont want to go higher than 6000 rpm so I dont have to get too crazy with the springs.
  5. #5 Re: Looking for a tuner in Hampton Roads area of va.
    Mar 2013
    Norfolk va
    Can anyone recommend a good tunerin or close to va?
  6. #6 Re: Looking for a tuner in Hampton Roads area of va.
    Mar 2013
    Norfolk va
    I'm kind of surprised there aren't more guys tuning that are looking to make some extra money..
  7. #7 Re: Looking for a tuner in Hampton Roads area of va.
    Mar 2013
    Norfolk va
    Still no tuners huh? Overkill it is lol
  8. #8 Re: Looking for a tuner in Hampton Roads area of va.
    Jul 2014
    Virginia
    I have a dhp im in VB. I dont know how to use it and havent got it up and running yet.
  9. #9 Re: Looking for a tuner in Hampton Roads area of va.
    Mar 2013
    Norfolk va
    Yea, reason I haven't bought one is because I'm afraid I'll blow my engine up. Lol
  10. #10 Re: Looking for a tuner in Hampton Roads area of va.
    Mar 2013
    Norfolk va
    I also have a 06, gto. So I use the gp as my daily driver..
  1. Looking for a tuner in Eau Claire, WI area
    By luckytii7 in forum Midwest
    Last Post: 03-15-2014, 11:58 PM
  2. Need A tuner in the DE PA MD NJ area
    By acidcrashdburnd in forum PCM Tuning
    Last Post: 05-11-2012, 10:37 PM
  3. Tuner in the GTA or Whiby/Oshawa area
    By matt5112 in forum PCM Tuning
    Last Post: 05-22-2010, 08:17 PM
  4. PCM Tuner in the NYC Area?
    By ARFF22 in forum PCM Tuning
    Last Post: 01-14-2010, 10:28 AM
  5. New Member from Hampton Road, VA area
    By IGGYS 2008 GXP in forum Introductions/Noob Questions
    Last Post: 01-27-2009, 02:41 AM
