Thread: new cam tune
Results 1 to 13 of 13
  1. #1 new cam tune
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    So i'm finishing up my s1x install today. Afterwards I'm going to follow a few of the tuning guides and do a full ve then maf tune Using Dhp. My question was is there anything in particular I should do to the tune besides just a base tune? Should I remove any codes (if so how), should I up my idle, should I raise my shift points, etc. I'm shifting around 6200 I believe now. Any help would be great, thanks.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  2. #2 Re: new cam tune
    Donating Users timboku's Avatar
    Montgomery, IL
    Not trying to be rude at all, but have you tuned? Your going to do a ve and then a maf tune but do not know how to remove a code? You need to tune your trims or.maf before a ve tune, and you should have a good working knowledge of tuning before a ve tune.. You dont want to.mess up your motor not knowing how to tune...most raise the idle a little bit on a cam, remove the misfire code so your ses doesnt light up. Raise the shift based.on your supporting mods etc. Theres a dhp guide that shows how to remove codes as well see if I can dig it up if you dont already have it.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: new cam tune
    Jan 2013
    Raleigh, NC
    I couldn't find the guide on removing codes that why I asked on that one. I have a good idea about how to do the full thing based on the other guides (garys, jerrys). I'm going to get it running, the unplug the maf and reset my trims, let them settle in for about an hour or so of driving based on the guides, then go from there. I got the gist, just need some clarification.
  4. #4 Re: new cam tune
    Montgomery, IL
    Cool.all good..jerrys guide has how.to.remove the codes iirc.
  5. #5 Re: new cam tune
    Jan 2013
    Raleigh, NC
    I'll reread it. Thanks.
  6. #6 Re: new cam tune
    Feb 2009
    flintnasty MI
    It doesnt seem to matter how many times ve tuning gets debunked and people still want to talk about it.
    Just put it together and figure out what doesnt work anymore and fix it. "Tuning" maf sensors and stuff for fuel trims is futile with narrowbands.
  7. #7 Re: new cam tune
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i certainly dont suggest or condone tuning with narrowbands. however, i would not describe it as futile. it has worked for a lot of people in the community for a long time. like since DHP was first released....
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  8. #8 Re: new cam tune
    Jan 2013
    Raleigh, NC
    So are you saying I should put in a new cam and not tune it? How would you do it?
  9. #9 Re: new cam tune
    Montgomery, IL
    I have the powertuner guide if you need it shows how to remove codes..pm me your email and I can send it if you dont have it.
  10. #10 Re: new cam tune
    Jan 2013
    Raleigh, NC
    Pmed
  11. #11 Re: new cam tune
    Kemmerer, Wyoming
    you can get the maf reasonably tuned with narrow band o2 sensors. you can use eddies table modifier thingy to tune the maf and ve, as well as add timing.
  12. #12 Re: new cam tune
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by SgtMarshal View Post
    Thats my plan. I might not do too much in the VE, but i'm going to see how it runs and if need be touch the maf.
  13. #13 Re: new cam tune
    Arizona
    Ve tuning was never debunked by dh
  1. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  2. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  3. E85 tune why? How?
    By Adam D in forum General Tech Discussion
    Last Post: 01-31-2013, 11:04 AM
  4. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  5. so i got a tune....again....
    By QwikGT in forum Off Topic Discussion
    Last Post: 11-19-2009, 10:48 PM
