Thread: afr in other gears?
Results 1 to 11 of 11
  1. #1 afr in other gears?
    gardner,mass
    So is there any possible way to tune the afr vs other gears? And if not where should i have it sitting in what gear. Right now im at like 11.7 throughout second gear then when it shifts to third im seeing like 12.5. Car seems to be happy and im not really seeing any kr. Ive heard these cars like 12s anyway.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: afr in other gears?
    Not really, because look at how the PE is setup.
    It's just based off throttle % and coolant temp really, and there is an adder table as time goes on. So you can't change it by gear.
    They like 12's if your NA or maybe running E85, but I'd still keep it in the mid 11's to keep it safe.
  3. #3 Re: afr in other gears?
    gardner,mass
    Idk but that would meen that i need to keep the second gear in the 10s to have 3rd in the 11s.
  4. #4 Re: afr in other gears?
    Or set PE to a single number, zero out the adders and see if it stays around what you command.
    If it goes leaner on your wideband but your commaned AFR in the scanner stays the same, then you have fueling issues.
  5. #5 Re: afr in other gears?
    gardner,mass
    commanded is set to 11.8:1 and all adders are set to 0.
    Fuel pump is brand new and new ac delco fuel filter not long ago. I kind of wonder if one of the injectors is slacking though.
    Also what do you run for a wb? I think ima invest in a NGK and sell this one.
  6. #6 Re: afr in other gears?
    Do you have a re-wire though?
    Because after 10-15 seconds of WOT the power supply with the factory wiring can cause lower voltage to the pump.
  7. #7 Re: afr in other gears?
    gardner,mass
    Yes i have a rewire. So are you saying that your wb reads the same throughout all gears?
  8. #8 Re: afr in other gears?
    Banned
    CT
    Playing with the PE adder over time table I've been able to pretty much eliminate AFR changes into 3rd (on a blower car).
    It doesn't do the same thing at all with my turbo setup.
    Probably because Im only in 2nd gear for 2 seconds.
  9. #9 Re: afr in other gears?
    gardner,mass
    Quote Originally Posted by SnowFlake View Post
    Oh nice, ill look into this thankyou.
  10. #10 Re: afr in other gears?
    Just make it add .2 to .5ish more fuel in the spots needed and see what happens.
    I run a AEM wideband in both my car and truck, works just fine. I don't do this stuff for a living nor is my car making a bajillion hp and needing a better more accurate wideband.
  11. #11 Re: afr in other gears?
    Aug 2011
    colorado
    ^what snowflake said. look into "PE.RPM. vs TIME AFR" table. I try to time it so starts to richen up approaching the 2-3 shift point from a stop . . roughly
  1. ZZP Gears VS GMR Gears
    By ADrugDealer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-14-2014, 02:59 PM
  2. 3.29 gears
    By ScammingL67beast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2014, 05:59 AM
  3. no gears at all
    By pontiacgtp98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-04-2012, 07:11 PM
  4. gears
    By 443pearl in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-31-2012, 10:00 AM
