I have a video of what it's doing but no idea how to upload it here.. tried both speed settings neither worked
It does
What's the keyspan assistant btw
I don't have that adapter
Lol I no all this dude I had it hooked up earlier and uploaded a bin and everything I was just showing what it's doing.. I have a bootleg usb to serial cable
I don't have a keyspan adapter but I will more then likely get one
I have the cable driver installed everything's fine with it now.. it just keeps doing that though
its failing the registration of the cable. once its done it should keep. ive gone back and fourth between two pc with dhp and its worked every time since they were both set up.
make sure the cables are all tight too.
Did that too.. I've tried everything you can think of probably what drivers do you have for the adapter maybe I will try it then
https://www.dropbox.com/sh/npa8brtuz...j_Kzk9jKa?dl=0
Give that a try.. If you can't get in, LMK
I'm installing XP threw VMware on my Windows 8 laptop.. I'm picking my son up in a few though so I can't mess with the car until Sunday night but I will keep you guys in the loop.. if anyone has any ideas please let me know thanks!
I tried XP and the driver works BUT I out of curiousity unplugged the DHP from the car while it "registered" and it did the same exact thing as it did when it was connected therefore it is either the tuner that's bad or the usb to serial cable.. Just has me stressed cause it worked yesterday now it won't
it has to be plugged into the car, car key turned to run, not running, just on. or wont wont register.
pretty sure its getting power from the obd2 port. check that fuse, for the cigg lighter. maybe it blew? or test it with a phone charger or something.
Your missing the point I tried like normal didn't work.. I disconnected the cable and it did the same thing as when it is connected.. so it's either the cable or tuner
it wont register unplugged, does the same fail of that search bar if its unplugged, i know cause i did it too, usb was unplugged for like 4 tries, was like duhhhhh.
