Re: Can't get my DHP registered
<p>
even my desk top pc im using for the off board, i had to hook it up to the obd2 port, have a pcm plugged in, and power to it. went through on the second try on the desktop pc. only cause i knew how to do it once, so it was easy the second time. it is possible the cable is bad, im sure you can test it with a ohm meter. maybe the pins are dirty? try cleaning them with elctrical parts cleaner maybe? dab of di electrical grease on the plug, work it in good by taking the plug off and on a few times.</p>
Does anyone know how to test the DHP to see if it works or is getting power?
I'm meeting up with a friend that has DHP that works and we are gonna use his laptop etc to try mine.. btw just curious what kind of usb to serial cable you have? I opened up the tuner and nothing on the board looked burnt etc when I hook it up a red light flashes as you said but it won't connect to the interface still
If I got it and it never worked I'd say **** I got a bad tuner BUT it worked and then a hour later had issues with the driver and it never worked again
try swapping the cables with your friends, see if then registers to your laptop. or try to register his to your laptop. if his working unit wont register, its your lap top or its setting.
I don't have any friends with a DHP, the only person local to me is dark horse, but it doesn't look like he's interested in helping.
I will figure it out dude just give me 2-3 days max and I will have some sort of a answer for you
ill say it again, it took me two weeks worth of nights f-ing with it till it worked. can be the worst time ever.
worst part is theres not a whole lotta help via google. same damn threads over and over in the search.
http://i1289.photobucket.com/albums/...ps1c01f64e.jpg
Here's a pic of my tuner. Anybody have any info on it? Doesn't look like the led is even hooked up to anything. Any thoughts on what software version I need to use or does it matter?
mine says 2.0/ X^$*@ for the firmware. cant find a anything that looks like a led on the case at all.
I tested both cables. Using an ohm meter I tested for continuity 1-10 on the serial cable. It had an even amount of resistance on each
http://i1289.photobucket.com/albums/...ps4f50fff4.jpg
sounds like its in the set up not being set up right in one last spot. or a driver thats not jiving.
http://i1289.photobucket.com/albums/...ps40fd7888.jpg
Then testing the obd cable I found these results:
2:2, 4:4, 5:5, 6:6, 7:7, 10:10, 13:15, 14:13, 15:14
I didn't find any continuity on pins: 1,3, 8, 9, 11 or 12
The numbers to the left of the colon correspond to the cable on the right in the pic and vice versa. Do they sound correct?
wish i had a ohm tester to see what mine are.
what about the box itself or the obd cable? Can you confirm my obd cable checks how it should?
thats how mine all looks.
i have not taken the cables off since i got it to work the first time.
Can someone please confirm whether or not my obd cable is checking correctly or not?
http://i1289.photobucket.com/albums/...ps6ca74cc1.jpg
Does anyone know what data bits, parity, stop bits and flow control should be set at in the keyspan?
mine looks just like that in that window, but mine is set to 57,600
Yea I tried them both. I'm starting to think my unit is defective. Darkhorizon is suppose to help me diagnose the problem. I'll let you know
