Thread: Can't get my DHP registered
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 99
  1. #41 Re: Can't get my DHP registered
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    I have a video of what it's doing but no idea how to upload it here.. tried both speed settings neither worked
    ZZP 10.3mm Wires, Autolite 605s, CAI, HP Tuners PCM,
    3" Catted DP, Straight Piped, 20% Tint, 5k HIDs, 6k Fogs
    220a (eBay) Alt , RF Prime Amp 1333w (RMS), Kicker 12" L7 750w (RMS), RF PBR Amp 75w (RMS x4)
    Alpine Type R (Front 5.25" 90w (RMS Each), Rear 6"x9" 100w (RMS Each)
  2. #42 Re: Can't get my DHP registered
    up load to photo bucket, then link it here.
  3. #43 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
  4. #44 Re: Can't get my DHP registered
    i can find no speed setting for the key span or anything that will show its speed, it only works on the lower speed 57,600.
    open up the key span assistant, check its comm port, and speed if it shows. match the comm ports and speed in dhp.
  5. #45 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    It does
  6. #46 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    What's the keyspan assistant btw
  7. #47 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    I don't have that adapter
  8. #48 Re: Can't get my DHP registered
    so your going right into the sierial port? or you have a usb cable set up?
    oh and was your car running? if so its car to on, not running.
  9. #49 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    Lol I no all this dude I had it hooked up earlier and uploaded a bin and everything I was just showing what it's doing.. I have a bootleg usb to serial cable
  10. #50 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    I don't have a keyspan adapter but I will more then likely get one
  11. #51 Re: Can't get my DHP registered
    radio shack deal? if you need a driver for it.
    i cant link you to a driver if need be
  12. #52 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    I have the cable driver installed everything's fine with it now.. it just keeps doing that though
  13. #53 Re: Can't get my DHP registered
    its failing the registration of the cable. once its done it should keep. ive gone back and fourth between two pc with dhp and its worked every time since they were both set up.
    make sure the cables are all tight too.
  14. #54 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    Did that too.. I've tried everything you can think of probably what drivers do you have for the adapter maybe I will try it then
  15. #55 Re: Can't get my DHP registered
    https://www.dropbox.com/sh/npa8brtuz...j_Kzk9jKa?dl=0
    Give that a try.. If you can't get in, LMK
  16. #56 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    I'm installing XP threw VMware on my Windows 8 laptop.. I'm picking my son up in a few though so I can't mess with the car until Sunday night but I will keep you guys in the loop.. if anyone has any ideas please let me know thanks!
  17. #57 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    I tried XP and the driver works BUT I out of curiousity unplugged the DHP from the car while it "registered" and it did the same exact thing as it did when it was connected therefore it is either the tuner that's bad or the usb to serial cable.. Just has me stressed cause it worked yesterday now it won't
  18. #58 Re: Can't get my DHP registered
    it has to be plugged into the car, car key turned to run, not running, just on. or wont wont register.
    pretty sure its getting power from the obd2 port. check that fuse, for the cigg lighter. maybe it blew? or test it with a phone charger or something.
  19. #59 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    Your missing the point I tried like normal didn't work.. I disconnected the cable and it did the same thing as when it is connected.. so it's either the cable or tuner
  20. #60 Re: Can't get my DHP registered
    it wont register unplugged, does the same fail of that search bar if its unplugged, i know cause i did it too, usb was unplugged for like 4 tries, was like duhhhhh.
  1. Just Registered ! From INdiana
    By Logan in forum Introductions/Noob Questions
    Last Post: 09-10-2010, 11:45 AM
  2. Finally registered.. red gtp
    By Perry125 in forum Introductions/Noob Questions
    Last Post: 08-22-2009, 09:58 AM
  3. finally registered....
    By kfog in forum Introductions/Noob Questions
    Last Post: 06-20-2009, 10:44 AM
