Thread: Full Write or Partial??
Results 1 to 20 of 20
  1. #1 Full Write or Partial??
    The Boss Iceman6669's Avatar
    Jun 2011
    Other then the sheer amount of time difference is there any reason to NOT do a Full Write everytime I flash a tune?
    2011 F-150 Yote powered
  2. #2 Re: Full Write or Partial??
    Jan 2014
    minnesota
    im not 100% sure, but iirc, with DHP PT, when you partial flash, you cannot brick your pcm. whereas with a full flash, you are taking that risk of bricking your pcm if your laptop loses power, the pt box takes a dump, battery power goes to low, etc.
  3. #3 Re: Full Write or Partial??
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I would full write every time just to be safe. That is what I always do! Just make sure everything is charged appropriately
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  4. #4 Re: Full Write or Partial??
    i set it on auto, it knows what its doing lol yeah right......writing to the same file with new updates goes much faster then reading the pcm.
  5. #5 Re: Full Write or Partial??
    May 2008
    Schuyler, NE
    Don't do a full write unless you are changing osid's.
  6. #6 Re: Full Write or Partial??
    Jun 2011
    It just seemed that on a few cars if I did a partial write the car would act completely retarded with stuff like trans settings, but with a full write everything worked fine.
  7. #7 Re: Full Write or Partial??
    Jan 2014
    minnesota
    Quote Originally Posted by Iceman6669 View Post
    are you using DHP or HPT?
  8. #8 Re: Full Write or Partial??
    Jun 2011
    DHP
  9. #9 Re: Full Write or Partial??
    Jan 2014
    minnesota
    i as well use DHP PT and never have had the issue you mentioned earlier after partials.
    i would recommend that you make sure all the connections are secure on the box and port (i do not use the usb adapter, i have an older "good" laptop w/ a serial), use a battery charger/jump pack and plug in your laptop during the write if possible. make sure you are using the same modified file from the last full flash.
    while i dont always use a jump pack and plug in my laptop, i try to.
    since i do not know how the partial flash works entirely, i do not know if it references the change log of the file you are working on to know what to flash and not what to flash. so i try to stick to the same file and do not swap back and forth from one branch to the other...
    example....
    ...............top swap bin option 1
    stock bin<
    ...............top swap bin option 2
    dont full flash option 1, then partial option 2.
    i would only partial option 1a, 1b, 1c, etc. if i wanted to try option 2, i would full flash, then partical option 2a, 2b, 2c, etc.
    make sense?
    are you using tiny tuner at all? i have heard that some tables are not mapped 100% correctly. i try to limit my changes to the PT software, and only going into tiny tuner to modify a table i dont have access to in the PT.
  10. #10 Re: Full Write or Partial??
    Jun 2011
    Yea I use tiny tuner. And I understand what your saying. It just seems that when I flash a car with a partial write, (on one car in particular) it seems to forget all learned settings in the trans and it acts full retard. No issues with the write, full power and everything works ok. Just sometimes the effects are different between the full and partial.
  11. #11 Re: Full Write or Partial??
    It's def interesting to see what folks post. A long term DHP user that knew Charles personally etc etc told me when using a DHP there are a few things that you always do.
    Always have a spare pcm with your last good tune on it
    Always do a full write.
    Then I see guys like DH etc saying partial is good. Just last week or the beginning of this week.. a guy said it only took him a couple min to write. Which..anyone with a DHP know.. you'll get at least a beer per write.
  12. #12 Re: Full Write or Partial??
    Bastard Reptile's Avatar
    Kansas City, MO
    Also, they said that you HAD to use the keyspan adapter...etc etc. I bought a $5 adapter on ebay that I use to this day.
    If I do a few changed, it's partial. There's no reason to sit for 5+ minutes just because you changed one setting. Auto all the way on a tweak, Full when you're actually putting something completely different on the PCM. I've never bricked a PCM on DHP.
  13. #13 Re: Full Write or Partial??
    i just flashed my pcm tonight with new deleted codes. i set it on auto, and it took like 2 minutes to flash the changes.
  14. #14 Re: Full Write or Partial??
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I really doubt it matters... I mean, we're just changing zeros to ones and ones to zeros where appropriate, correct?
    Seems redundant to re-write the same data to memory. Just takes more time and more wear on the memory (although probably no endurance issues here).
    If it does matter, like these partial write phantoms, sounds more like a flaw in the software/hardware doing the changes.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  15. #15 Re: Full Write or Partial??
    hangover park IL
    i do partials, can always recover, DHP/TINY/UVscan.
    faster to do a partial and reset adaptives
    where ive flashed a 96-03 down to nearly 10v the 04+ ****ing hate anything less than 11.5...98/99 bins ftw, **** all the Eobd2 crap for 00+
    ~James~ Psychotic Gearhead
  16. #16 Re: Full Write or Partial??
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    using HP tuners
    My 07 can with 05 PCM can only be flashed at slow speed. But I do partial flash only
    Always partial flash for my other GTPs 97-2000 and 2000. Never had a problem. High speed for all these ones.
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  17. #17 Re: Full Write or Partial??
    gardner,mass
    What im curious about is do people actually have issues with having to remove there radio fuse when flashing? Ive been doing it just for sake of comfort because i hear you can brick the pcm without doing so on the 04 +.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  18. #18 Re: Full Write or Partial??
    You have an HPT correct? DHP is a much older critter. The issue appears to be that the data lines on the 04+ are much more congested, therefore by removing the fuse you disable a few things from talking. Years back Monte guys were putting in a switch and totally bypassing the rest of the car while writing. They'd run a dedicated line with switch to go straight to the pcm only.
  19. #19 Re: Full Write or Partial??
    hangover park IL
    too many digital idiots screaming for attention on the 04+ databus
  20. #20 Re: Full Write or Partial??
    gardner,mass
    so 04+ doesnt have issues with hpt? Cus i remember back at jasons when you set my egr and cat to no report you didnt remove the fuse but then again thats not really a big adjustment. I just dont want to get stuck somewhere without a pcm but it does get rather anoying removing the fuse everytime and not listening to music while scanning just cause its easier to leave it out.
  1. Full guage shows full when it's 1/8th tank - car won't start?
    By Y2KGTP in forum General Tech Discussion
    Last Post: 05-30-2014, 08:24 PM
  2. Full tank of fuel gauge floats between full and empty.
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2013, 06:17 PM
  3. 'Partial' Gen V Install Pics
    By Street Wolf in forum General Tech Discussion
    Last Post: 07-14-2008, 10:47 PM
