Ya I adjusted both actual and commanded are very close now
The maf is a MEASUREMENT OF ACTUAL AIRFLOW coming in.
Think of it this way...
Guy at gate of stadium = MAF sensor
Guy seating people = Motor
There is a guy at the front of a stadium with a watch and counts how many people are walking in the door.. If the rate of people coming in the door changes the guy counting and watching his watch will still report back how many people are coming in, regardless of why. These people can be getting pushed in, or the people could be less restricted to their seats after they get in the door, but the guy at the gate is JUST counting air coming in.
The guy seating people is your motor.... The cam makes your engine seat people faster, but there are still just as many people to seat. The cam makes for less congestion after people get in the door so more people can get in, and the guy at the gate will count more people going in.
That was the best thing I think I've ever read. :)
It goes like this....Factory puts together your engine and calibrates the PCM so that it expects a given amount of g/sec measured from the MAF at that SPECIFIC HZ rating, However things happen to that specific calibration once a aftermarket airfilter assembly ported tB...etc etc get installed. The g/sec value changes for the HZ rating reported to the PCM. I understand your against maf tuning in general due to the complexities of fitting a 3rd order poly to it to keep the math correct. But understand that raping your IFR table isnt the only way to get what you want...Theres alot who will say youre way is bat **** cray cray, and there are some who might agree with you, But until that day comes ill take my knowledge base from people who actually write factory software for a living.
First you were talking about adding a cam... then you are talking about building a new maf from scratch... lets get your stories straight.
Also the "air filters change it" story has been played out and its easier to make linear changes like that to the injector table if you put a air filter on that creates some lame airflow thing.
Never did I say cam seriously...like ever
And u still won't find where I said cam at this point you should use your the words in your signature
You pointed at it and said "this case you should maf tune" now that I spell it out you're mad bro. Im sorry
Xp cam headers cobra 39lb 3.3mps open cone
Fuel trim got a little crazy again but gas cap light came on so think that what it is
Did take a look at my maf tune last night and it's not as linear as the stock one so prob a contributing factor
Interestingly enough, I installed 60lb EV1 injectors this morning into my 99 GTP.. Set the injector IFR tables appropriately (between 62 and 67). Driving around a bit and getting on it, my AFR's with the wideband look great as usual (14.7 cruise, 12 at high throttle, 11 at WOT). Similar to your case, my LTFT's are way off. I see high values (up to 16.4 sometimes, and usually at least around 7 or 8) but then when I get into the throttle/PE mode, they drop to zero. Everything else looks fine... :th_coocoo:
Note that I have never touched or changed the MAF table yet. Only my PE tables and injector tables (and when I say injector tables, I only mean IFR).
you'll be surprised how much the cam and headers change the way the narrowband reads.
http://www.youtube.com/watch?v=kBk0KudOVAg Skip to 9:00
I didnt watch it because I am at work but I can tell you that just because some idiot made. Youtube video on it it does not mean he has any idea what he is talking about.
This dude has real credentials plus he actually can prove how things work.
You forge the tuning process. The computer never knows the real stoich value of the fuel its using. You falsify injector data and when airflow charteristics are changed you ignore them. Your method was viable with really old tuning software, but with all the ability now to get the PCM better able to handle real world driving you have to take a look at what needs changing
Airflow characteristics are not changing. The maf is not reading air differently because you put a sh itty intake on...
Im an engineer who works with people with real credentials and real experience but they have no ability to logically work through a problem.
