Thread: Tuning issue
Results 1 to 9 of 9
  1. #1 Tuning issue
    Jun 2013
    Hollywood ,FL
    Why does it seem like my tune changes by itself we command 11.0 and get 11.1 on a street run but then the next day at wot at 5k pmus rpms it leans out to 13-14afr by itself? Cars a 05 gtp
  2. #2 Re: Tuning issue
    Dying fuel pump?
  3. #3 Re: Tuning issue
    Jun 2013
    Hollywood ,FL
    For instance let's say 2 day I tune my car I can get it to run a perfect 11.0 all night the second the car sits overnight the following day at higher rpm it will jump up to 13 14
  4. #4 Re: Tuning issue
    Jun 2013
    Hollywood ,FL
    Could that be a cause of power enrichment or not blending the timing advance tables
  5. #5 Re: Tuning issue
    Feb 2009
    flintnasty MI
    closed loop vs open loop brah.
    Unplug the front o2 sensor and run open loop all day. You probably have the wrong injector constants or a busted maf table thats causing it.
  6. #6 Re: Tuning issue
    Jun 2013
    Hollywood ,FL
    Its closed loop
  7. #7 Re: Tuning issue
    Feb 2009
    flintnasty MI
    right, so run open loop if you cant figure out how to make closed loop work... its not a big deal and typically with cam cars you cant ever make it work right.
  8. #8 Re: Tuning issue
    Jun 2013
    Hollywood ,FL
    Yea I got a xp cam
  9. #9 Re: Tuning issue
    Jun 2013
    Hollywood ,FL
    Dark whats a down fall of running open loop
  1. Issue with A/C no more cold air and sound issue with Shocks
    By ibra0078 in forum General Grand Prix Discussion
    Last Post: 08-09-2013, 08:25 AM
  2. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  3. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  4. PCM tuning LTFT's issue
    By dharder in forum PCM Tuning
    Last Post: 12-09-2009, 11:54 AM
