Thread: e85
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
  1. #41 Re: e85
    Arizona
    9.85 for true E85, you can test stoich on your own with a small beaker, plenty of videos on youtube
  2. #42 Re: e85
    Feb 2009
    flintnasty MI
    Stock. I make changes in injector flow rate.
  3. #43 Re: e85
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    so you're stoich. Target stays at 14.7 even when you're running E85 and any mix between?!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  4. #44 Re: e85
    Bastard Reptile's Avatar
    Kansas City, MO
    In this case, the less you jack with the better. The pcm won't care.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk
  5. #45 Re: e85
    Feb 2009
    flintnasty MI
    Quote Originally Posted by 97AutoXVette View Post
    Yeah. People say they change thier stoich values but I always fear that youll also need to make changes in the pe tables. The ls pcms work off of equivalence ratio aka lamba so any change to stoich value carries to all of the stoich modifiers... thats where you typically hear of this value being changed.
  6. #46 Re: e85
    Mar 2014
    Cincinnati, OH
    So, in prepping for E85, my current tune has the stoich. target AFR adjustment (9.85). I also, modified my PE tables to target my WOT AFRs to be somewhere around 7.2 or 7.3 I believe.
    If you don't modify the stoich targets, won't the ECU continue to target what is in there? I guess you can change the injector tables to account for the ~30% additional fuel one would need for the stoich. of E85, but wouldn't the ECU just again re-adjust? UNLESS, the 3800 ECUs really do just target lambda = 1 until you get into PE mode, in which case it targets whatever Lambda is based on the PE targets.
    Let me know if that doesn't make sense. I definitely want to get this right as my injectors (60#) came in last night, and I will be making the changeover soon!
    2002 GTP sedan:
