Thread: need tune for 2002 gtp
Results 1 to 20 of 28
  1. #1 need tune for 2002 gtp
    Jan 2013
    Texas
    Anyone have a tune for a 2002 gtp with these mods:
    Cold air intake
    160 thermostat
    Speed daddy headers
    Zzp 3" stainless steel cat back with cat
  2. #2 Re: need tune for 2002 gtp
    Aug 2011
    'Merica
    why 160* tstat?
  3. #3 Re: need tune for 2002 gtp
    Because ZZP said so.
  4. #4 Re: need tune for 2002 gtp
    Aug 2011
    'Merica
    racecar........
  5. #5 Re: need tune for 2002 gtp
    Jan 2013
    Texas
    That's what I heard everybody uses is the 160, right?
  6. #6 Re: need tune for 2002 gtp
    Aug 2013
    McDonald PA
    No there is no point. Put a 195 back in
  7. #7 Re: need tune for 2002 gtp
    GTX Level Member crbquist's Avatar
    Massachusetts
    I'm on a 2.8 pulley and I run a 180*. 160 is way too cold for a near stock setup.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  8. #8 Re: need tune for 2002 gtp
    Jan 2013
    Texas
    Huh Ok. But still need a tune
  9. #9 Re: need tune for 2002 gtp
    Aug 2013
    McDonald PA
    Your basically stock put the 195 back in
  10. #10 Re: need tune for 2002 gtp
    Jan 2013
    Texas
    it doesnt really run @ 160 it runs like 175 or 185, but if the 160 could cause damage to the engine then i will. but i need a tune for my other stuff i have, going to, put on
  11. #11 Re: need tune for 2002 gtp
    Don't need a tune for some exhaust and an intake.
    If you really want to run the colder t-stat, then yes, you'd need a tune to change your fan settings, but that's about it.
  12. #12 Re: need tune for 2002 gtp
    Jan 2013
    Texas
    what would you tune if you were going to get one for these mods? just curious.
  13. #13 Re: need tune for 2002 gtp
    you dont need a tune till you drop pulleys, swap to a perfomance cam shaft or add a ic.
  14. #14 Re: need tune for 2002 gtp
    Banned
    CT
    I've tuned bone stock cars and picked up a half second in the 1/4 mile.
  15. #15 Re: need tune for 2002 gtp
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by SnowFlake View Post
    What did you do to those tunes?! Haha.. Fueling changes or bumped up the shift points?
    sorry, not trying to thread jack. Hoping this may help
  16. #16 Re: need tune for 2002 gtp
    Banned
    CT
    Just got the cars to stop knocking, then from there raised the shift points a little and had the trans shift firmer/faster.
    One guy in a Regal GS was running 15.1-15.2 all day and I talked him into a tune right there at the track... next pass was 14.5.
  17. #17 Re: need tune for 2002 gtp
    May 2012
    Where winter never ends
    Yeah a tune can defiantly help, but if you don't have constant access to a tuner then tuning at every small change is kinda pointless. If you plan on going further in your build, wait until you drop a pulley, get a cam or something that really changed how the motor flows.
    2000 Regal - Winter Beater
  18. #18 Re: need tune for 2002 gtp
    Tune helps on any car, regardless of mods.
    Trade off the 160* for a 180*.
    Get new wires/plugs if you haven't. Flip the factory mounts.
    Lots of little things you can do to help the car.
  19. #19 Re: need tune for 2002 gtp
    Feb 2009
    flintnasty MI
    Help is a strong word but I dont disagree. I wouldnt tune a car unless I had to and ive flashed over 2000 files to 3800s in my day.
  20. #20 Re: need tune for 2002 gtp
    Arizona
    There's a lot of trans work That can be done stock or not.
  1. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  2. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  3. Tune-up for 3.8 Supercharged 2002 GTP
    By falcongt in forum General Tech Discussion
    Last Post: 03-20-2013, 05:51 PM
  4. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  5. 2002 GTP vs. 2002 audi S4
    By JbrownGTP in forum Track Sessions and Kills
    Last Post: 07-07-2009, 11:50 PM
