Thread: How do I turn off the ABS light?
Results 1 to 13 of 13
  1. #1 How do I turn off the ABS light?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Is there a way to do this in the tune? certain DTC that I can turn off?
  2. #2 Re: How do I turn off the ABS light?
    As opposed to fixing the problem? Interesting question, I've never tried it. I believe all the wheel speed sensor and ABS are U codes and not available in the PCM which houses P codes. Might be wrong though.
  3. #3 Re: How do I turn off the ABS light?
    Mar 2014
    Cincinnati, OH
    I think you're right. I haven't been able to find any code that would allow me to turn it off. Wheel speed sensor went out and I am likely just going to leave it.
  4. #4 Re: How do I turn off the ABS light?
    Bastard Reptile's Avatar
    Kansas City, MO
    It's a body control function I believe, so it doesn't actually run through the PCM.
  5. #5 Re: How do I turn off the ABS light?
    Mar 2014
    Cincinnati, OH
    Darn... really wish I could turn it off...
  6. #6 Re: How do I turn off the ABS light?
    Dec 2012
    troll land
    Pull the bulb from the cluster
  7. #7 Re: How do I turn off the ABS light?
    Replace the sensor you bum.
  8. #8 Re: How do I turn off the ABS light?
    Mar 2014
    Cincinnati, OH
    Aren't they expensive?? Guess I should just look..
  9. #9 Re: How do I turn off the ABS light?
    Kansas City, MO
    A hub is like, $100 from Autozone.
  10. #10 Re: How do I turn off the ABS light?
    Aug 2011
    'Merica
  11. #11 Re: How do I turn off the ABS light?
    Nov 2011
    NY
    Not good to shotgun parts at a problem, you need to get your ABS sys scanned and then maybe you'll know if its a bad sensor/hub or a break in wiring, etc. unless you just want to throw $400 at 4 new hubs and maybe still have an ABS light!?!? Lol
  12. #12 Re: How do I turn off the ABS light?
    the free check is to jack each wheel up lugs still tight, then push and pull the top of the tire to feel for movement, you can watch the rote, if it moves in between the caliper you found a bad hub and likely the cause of the abs light.
  13. #13 Re: How do I turn off the ABS light?
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    And if worse comes to worse, pull the bulb...LOL.
    Official GPF Red Neck
  1. no right brakel light/turn signal
    By jjlw in forum General Tech Discussion
    Last Post: 04-01-2013, 11:09 PM
  2. Right Rear Turn Signal Out But Light Is Still On?
    By Joseph27705 in forum General Tech Discussion
    Last Post: 06-28-2012, 06:01 PM
  3. E-brake light wont turn off need help!!
    By zjeylani in forum Introductions/Noob Questions
    Last Post: 07-25-2011, 06:07 AM
  4. e-brake light wont turn off
    By basballny2 in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2010, 04:07 PM
  5. Glove box light wont turn off?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 10-27-2009, 06:32 PM
