Thread: Can't Turn Off Traction Control..
Results 1 to 11 of 11
  1. #1 Can't Turn Off Traction Control..
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Is there a mode or a number somewhere in the Hptuner I am not seeing that has made it so the button on the dash does nothing?
    Or what else can make it so the TCS can't be turned off?
  2. #2 Re: Can't Turn Off Traction Control..
    your abs light on too? if so fix that, and the tc will turn off and on again.
  3. #3 Re: Can't Turn Off Traction Control..
    May 2014
    Colorado
    nope abs is fine
  4. #4 Re: Can't Turn Off Traction Control..
    get it scanned. chances are its a bad hub, or bad wire, or dirty connection @ the plugs.
    scanning saves you from chasing it with parts. and no, the free scan at the parts store wont do it. you need to go to a garage and pay them to scan your car for these codes. around here most shops want 75 or more, then i found one that did it for 30 bucks, so he got my 30 bucks lol
    unless you buy a abs scanner of your own. seen em for about a 100 bucks.
  5. #5 Re: Can't Turn Off Traction Control..
    May 2014
    Colorado
    Wouldn't a bad hub or wire or something turn ON the abs light and disable traction control?
    The problem is I can't turn OFF traction control.
  6. #6 Re: Can't Turn Off Traction Control..
    i hear ya. the hub does both. tc and abs. one of the sensors could be bad. you got 4 of them. so the scan helps narrow it down.
  7. #7 Re: Can't Turn Off Traction Control..
    May 2014
    Colorado
    But a bad one of those can render the tcs button useless? That seems backward.
  8. #8 Re: Can't Turn Off Traction Control..
    Nov 2011
    NY
    Your fighting the logic of GM Engineers... Don't try to think rationally!
  9. #9 Re: Can't Turn Off Traction Control..
    May 2014
    Colorado
    Quote Originally Posted by coolone View Post
    Yeah that logic has confused me on more than one occasion.
  10. #10 Re: Can't Turn Off Traction Control..
    like i said, get it scanned. easiest way to find the issue. anything we say is nothing more then a guess.
    theres a list of free checks, like check for play in the hubs, broken or cracked insulation on the wires to the hub same for around the ebcm on the abs pump. check all them wires over too.
  11. #11 Re: Can't Turn Off Traction Control..
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I can post a huge paragraph on how to diagnose a bad WSS or broken wire with a DMM but I need to refine it so its less confusing. Getting it scanned is easier and tells you which HUB to look for problems at. I'm gonna invest in a scanner that does ABS codes I don't think they are that expensive.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  1. Traction control light only traction control
    By ccoimbre in forum General Grand Prix Discussion
    Last Post: 02-09-2014, 01:02 PM
  2. ABS and Traction Control not working but no ABS or Traction Control lights
    By jruether11 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2013, 04:40 AM
  3. Traction Control Off / Stability Control Off / Service ABS System
    By compro in forum Brakes/Suspension/Chassis
    Last Post: 12-21-2012, 09:37 AM
  4. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  5. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
