Thread: I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
Results 1 to 8 of 8
  1. #1 I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Removing the CAT and replacing with a ZZP Catless Downpipe. I am going to turn off the secondary 02 SES light but my question is why does a third sensor show up in the tune? Should I just turn off the SES lights for Sensor 2 and not worry about Sensor 3?
  2. #2 Re: I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
    What are you using to tune?
  3. #3 Re: I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
    There is no sensor 3 btw so no need to mess with it.
  4. #4 Re: I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
    Mar 2014
    Cincinnati, OH
    HP Tuners pro. I figured it was just in there as a standard option by chance but didn't want to go clicking things without checking.
  5. #5 Re: I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
    Anything rear o2 related just set to 3, no error reported.
  6. #6 Re: I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
    Mar 2014
    Cincinnati, OH
    That won't make anything in the ECU freak out and throw off AFRs right? I thought I saw a post of some guy and a horror story about changing the rear O2 setting and then his AFRs getting out of wack. don't see how/why that would happen though...
  7. #7 Re: I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
    1997-2000 PCM's don't care one bit about what the rear o2 sensor says. It's only there to say that the cat is working and there or it's not.
    I've turned off all related codes for it along with EGR stuff as I don't run either.
  8. #8 Re: I see DTC's for Sensor 1, Sensor 2, and....... Sensor 3?
    Mar 2014
    Cincinnati, OH
    Good to hear. I just turned off all DTCs related to Sensor 2. Thanks again!
  1. 0 KR rear sensor & 5-7 degrees KR front sensor
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 08:06 PM
  2. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  3. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
