Thread: How do I add fuel to just the decel and idle fuel cells?
Results 1 to 8 of 8
  1. #1 How do I add fuel to just the decel and idle fuel cells?
    May 2012
    Albuquerque, NM
    I just started my tune after installing my heads. I replaced my 22# injectors with 60# to go with the turbo but now my idle and decel fuel cells go very lean, 17+ on the WB, actually dies on occasion. I know I can correct fuel as I modify my MAF table but this doesn't add fuel in lean condition. Is there a way to add fuel into just those two cells?
    TIA,
    Slim
    2003 Chevy Inpala LS 3.8 l36, Stattama Turbo kit, P&P LIM, P&P heads, lS7 lifters, Intense Xtreme 7.05 oil restricted pushrods, ZZP 1.9 modded rockers, 3" no cat down pipe, poly mount all around, fuel rewire, alt volt booster, and still working on it...
  2. #2 Re: How do I add fuel to just the decel and idle fuel cells?
    If you enter DFCO if will spike lean and make it seem like an issue as the motor just becomes an air pump. You can shut off DFCO if you wanted and it will never do that.
    And it sounds like you need to maybe get the right data for the injectors in the PCM if you are running 17 at idle, if your stoich is still set at 14.68.
  3. #3 Re: How do I add fuel to just the decel and idle fuel cells?
    May 2012
    Albuquerque, NM
    I'm sorry, let me restate the issue. Once I let off the gas it temporarily spikes lean for no more than a second or so. During idle, it will bounce into and out of lean.
    As for my injector fuel rate: the stock injectors were 22# (right for an L36?) at an 367 flow rate, the Siemans Deka injectors are rated at 65# per the ZZP site. My math was 22/65=.3385, 367*.3385=124.23
    Isn't that correct?
    Slim
  4. #4 Re: How do I add fuel to just the decel and idle fuel cells?
    May 2012
    Albuquerque, NM
    Also, what is DFCO?
  5. #5 Re: How do I add fuel to just the decel and idle fuel cells?
    I couldn't tell you if the data is correct.
    But what you are seeing on the wideband for the afr when you let off the gas is 100% normal, there really isnt anything you can do. It's not hurting anything because it can't. You let off the gas, injectors cut back to near nothing and the plate allows air in still for a short time, so the extra air just goes through with little to no fuel in a non load situation thus the WB showing lean. Sure thats not a super duper correct answer, but it's pretty much what happens.
  6. #6 Re: How do I add fuel to just the decel and idle fuel cells?
    May 2012
    Albuquerque, NM
    Cool. I appreciate your time. So I shouldn't worry about those two cells too much? The main reason this came up is the car occasionally dies while driving when I let off during boost. Could that be part of the issue or should I look else where?
  7. #7 Re: How do I add fuel to just the decel and idle fuel cells?
    Florida
    I recently dealt with the same issue. like said it normally isn't not going to hurt anything. me being top swapped i wanted it perfect, so i dove in deeper. I started lowering timing in the areas where the WB was lean. it corrected the problem. lowering timing is not going to hurt performance as this is not a cruse or wot or part throttle area. you are logging your wide band right? just watch where in relation to your timing table the AF goes lean and correct it.
  8. #8 Re: How do I add fuel to just the decel and idle fuel cells?
    May 2012
    Albuquerque, NM
    I found out by trial and error that the 2bar MAP (even with the files swapped) was a no go for my car and was likely why my LTFT were so screwed up. Changed the MAP back to stock and no problems since.
  1. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  2. fuel pressure is 40 at idle.....
    By alivepills in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2011, 09:34 AM
