Thread: what to expect with timing advance
Results 1 to 8 of 8
  1. #1 what to expect with timing advance
    SE Level Member TehGTP's Avatar
    May 2008
    Saint Louis, MO
    The last time my car had some changes done to the PCM was when it was down in Indiana with Trannyman95 getting one of his awsome transmissions.
    at the time mods were 3"DP/plog/3.4/al104's/thrasherCAI
    ive since added 2.5" catback, headers, and 1.9 modded rockers.
    i havent seen KR in a lonngg time..
    my question is, with my timing being set at 11* as is. what sort of power gains would be expected granted i can get to my target 17* timing??
    thanks for the help yall!
    2007 Corvette Z06 - BFD Cam / E85 / milled & fixed heads
    2006 GTO M6 18's - SOLD - VRX5 Cam | FAST 102 | Exhaust
    2001 GTP - SOLD - 1.9 | TOG's | E85 | LC1 | B+G | AGX | GMPP | 3EP
  2. #2 Re: what to expect with timing advance
    Barksdale AFB, LA
    General rule is 1.5-2HP for every degree. Do the math.
    2009 Subaru Impreza WRX STI
  3. #3 Re: what to expect with timing advance
    11* of timing is almost nothing..
    id try and run 18*+ all the time if it were possible.
  4. #4 Re: what to expect with timing advance
    May 2008
    Saint Louis, MO
    ^^^ agreed.
    ill try to run as much as i can. but in my situation i have no access to tuning software and im not about to spend $400 on a local tune...
    i just figured 17* would be a semi-safe number. i would be in heaven if i could run over 18* KR free
  5. #5 Re: what to expect with timing advance
    Quote Originally Posted by TehGTP View Post
    ^^^ agreed.
    do you have a scanner atleast? why i ask is if u know a local around the area that has a PT or HP tuner they can unlock your IAT spark advance. once u have that opened and have it adjusted accordingly to either add/subtract timing based on what the IAT is registering. the next step would be is cut off the iat sensor functionality itself and reroute the wires to something that u can fake what the ambient air is to the pcm. what u can replace the iat sensor with is something that can adjust the frequency or ohms the pcm reads from the sensor that it incorporates into temperature. a really good tool is whats known as a potentiometer(just google-search it) or nicknamed a "pot". that way u can add/subtract timing whe in PE/WOT if u see KR or not. its basically what a "happy knob" as well as the timing change on the ICCU does.
  6. #6 Re: what to expect with timing advance
    if i go to the track im going to see if i can lift my heads off the block..24*+ baby.
  7. #7 Re: what to expect with timing advance
    May 2008
    Saint Louis, MO
    i like your style
    i used to spray in the waterbox with my LS1
    i need to bite the bullit and buy HPT
  8. #8 Re: what to expect with timing advance
    May 2008
    Saint Louis, MO
    ^^^ thanks for the input.
    yes i have a scanner, if you wanted to see some logs i could post some up..just a 1v sensor though for now.
    i was mainly intrested to remove the skew from my front cyl's from when plog was on.
    up timing overall 5-6*
    raise idle up just a ball hair.
    since my o2's seem ok and LTFT stay pretty close to 0 WOT i figure why change anything else when i would possibly hurt more than i could help. know what i mean?
  1. Front Strut Mount from Advance Auto Parts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 04-02-2009, 11:53 AM
  2. 98 GTP- What to Expect?
    By SMM2469 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 10:19 PM
  3. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
  4. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  5. How long should I expect my car to last?
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2008, 12:11 PM
