Thread: AFR and Timing Tuning (02 Regal GS 223k!!!)
Page 5 of 5 FirstFirst ... 345
Results 81 to 92 of 92
  1. #81 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Feb 2009
    flintnasty MI
    Quote Originally Posted by PWNED View Post
    How are the initial #'s found though? Going from stock to bigger injectors to start off where you need to be.
    I can't seem to find the post now but I thought I came across you saying 21% would need to be modified for a 42 and 19% for a 39#.
    I didn't understand.
    Stock injectors are 33.7# and yours are 41.5#... Math says how much bigger the bigger ones are.
  2. #82 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Stock vs 42 (mine)
    What are you saying divide 33.7 by 41.5? Then x by that value
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  3. #83 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Feb 2009
    flintnasty MI
    Looks good.
  4. #84 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    Looks good.
    As in leave it alone?
    02 Regal GS
  5. #85 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Feb 2009
    flintnasty MI
    its good for a base.
  6. #86 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    For better mpg's is there anything here that should be touched? As I am catless.
    02 Regal GS
  7. #87 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Gains for MPG is 100% done in the timing table on these cars. And your right foot.
    Most will increase the timing during "cruise" parts of the table to help get an extra 1-2 mpgs on the freeway.
    I took a 2004 GTP file and ninja rigged it with my 00 GTP file. The 04+ cars got a more aggressive timing map than the older years, pretty much just have to combine them and make it nice.
  8. #88 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Feb 2009
    flintnasty MI
    Wrong. Tons of real mpg is gained by disabling cat warmup... close guess with the overtemp its usually a good idea to set those numbers to 11.00 because you should never hit those and if you did it would effect wot too.
  9. #89 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Meh, I have everything cat converter related shut off.
  10. #90 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    Is that the correct temp?
    Would putting all of that at 11.0 make it run rich in general? How does making it all 11.0 instantly net better mpg's?
    02 Regal GS
  11. #91 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Look at what the table is for, its only for "cat overtemp protection".
    Thus the only time it will ever go to a commanded AFR of 11 (if set to it) is when the coolant temp is above 240ยบ.
  12. #92 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    There's probably some other "hidden" feature that only darkhorizon knows about ffdp. But in all seriousness max out that temp for cot. Set Afr to what your p.e is set at and leave alone. I would completely agree with ffdp. Timing in cruise areas is very important and can net you 1-2 mpg more.
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. Pulley / Timing / MAF tuning with elevation change
    By Impala131 in forum PCM Tuning
    Last Post: 02-21-2013, 04:15 PM
  3. 1998 Regal GS Tuning Question
    By DrGSXR750 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 04:38 PM
  4. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
