Thread: AFR and Timing Tuning (02 Regal GS 223k!!!)
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 92
  1. #41 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    Quote Originally Posted by PWNED View Post
    What are the exact years of trucks that have this? I searched real quick and some state it is in a different format? If I want to play around just for future reference it would be nice to know how to do so. Any exact link?
    The lq4 is set up for different characteristics like a v8. We just have to modify the table as it gets us started. Kind of like starting off a stock l67 maf table and modifying the hell out of it.
    I will be going to stock maf this is just a pita.
    it really dosent matter, drop in the LQ4 MAF table. then tune from there. thats the purpose of MAF and VE tuning.. with the MAF just tune via either LTFT or STFT till you +-5%
    heres that screenshot
    ill see what i can get for the LQ4 maf however with it being a common upgrade you should find it readily available possibly on the HPtuners repository
  2. #42 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Quote Originally Posted by 91parkave View Post
    Perfect, much appreciated! Is it best to use what I had as a screen shot via the other member's config or use what is pictured above?
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  3. #43 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Feb 2009
    flintnasty MI
  4. #44 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Feb 2009
    flintnasty MI
    If you have problems.... Let me look for the "right" one I have on my laptop.
  5. #45 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    The problem I have with the one from zzp is that the values are more than doubled almost tripled.
    For example at hz rang 10625 my file states 42.381 vs the one from zzp at that same hz is at 292.14
    I know I hit that part of the maf and if I am at 11.0 afr for example now that would make it waterfall rich.
    That is why I am very confused on what to do if I put that file in my car would run extremely rich.
    02 Regal GS
  6. #46 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    IMO stick with your current mad table and tune it from there. Regardless you'll end up with a table that works. A couple nice drives and you should be just fine
  7. #47 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    Is there somewhere that states what that PID exactly does/means? Also what does the <20 mean? Where have you learned this?
    Just set mine up like this atm.
    02 Regal GS
  8. #48 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    Pid is for fuel trim cell like I mentioned in earlier posts. And i be just learned from reading countless hptuners threads about tuning. Like I said before though click that blue icon and verify your fueltrim cell pid, and maybe someone else can verify fuel trim cell numbers but anything under fuel trim cell 20 is part throttle acceleration which is the data you want. Not decel not evap nothing other than part throttle accel data.so fuel trim cell under 20 works.
  9. #49 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Feb 2009
    flintnasty MI
    Zzp table is in dhp format. See if you can convert hpt to the correct one. If not download any 6.0l tune off the hpt website and use it.
  10. #50 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Feb 2009
    flintnasty MI
    http://www.hptuners.com/forum/showth...table-question
    try doing an import or something.
  11. #51 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    Attached are your tables LQ4 drop these numbers in and go MAF tune, which is done by either using your wideband or using fuel trims. Itll take a couple iterations but everything will settle in
    AFR and Timing Tuning (02 Regal GS 223k!!!) Attached Files
  12. #52 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    What is the blue icon you speak of?
    Also when I get the scan how do I go about modifying it?
    Just part throttle not in pe for this part? Or do I go wot , city, idle scan?
    02 Regal GS
  13. #53 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    look in the screen shot i posted with the formula next to filter theres a blue question mark symbol. click on that. it brings up all available PID's.
    for your scan pwned.JPG click where i showed you to highlight the table then in your tune open your maf (or VE depending on what your doing) table and right click---paste special---multiply % half.
    This will apply your new settings, flash to vehicle reset fuel trims and do it all over again. till your trims look +-3
  14. #54 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    Awesome! I think I got it.
    Lets take my last scan for example and load it into the histogram filter you stated as seen. Right click copy (averages) blank is where it did not hit 90 counts (in the scan)
    Now right click---paste special---multiply % half and it will do its thing (in the tune file)
    Is there a certain hz I need this to go up too? Will it not read anything higher than 20% throttle? Do I need to disable PE or be careful not to enter?
    02 Regal GS
  15. #55 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    for maf tuning you should disable PE,
    *correction i found my table that i use for the cell that formula should be (PID.6310)<14
    seen here
    Fuel Trim Cell Info
    0 : Non load (? Coast or idle)1 : Non load 2 : Non load 3 : Non load 4 : Non load 5 : Non load 6 : Load Part throttle 7 : Load Part throttle 8 : Load Part throttle9 : Load Part throttle10 : Load Part throttle11 : Load Part throttle12 : Load Part throttle 13 : Load Part throttle 14 : Load Part throttle 15 : WOT 16 : Idle PARK, A417 : Idle NEUTRAL, A418 : Idle Engine warm?, AC on, M619 : Idle Engine warm?, AC off 20 : Idle Engine Cold?, AC off21 : Non load (? deceleration) 22 : WOT
    Non load cells 0-5, 21
    Idle 17-20
    Part Throttle 6-14
    WOT 15, 22
    but the other info yes try not to go over 60-70%throttle- disable PE take your scan results paste into tune multiply half percent flash to vehicle reset fuel trims, rince and repeat.
  16. #56 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    seen here
    Fuel Trim Cell Info
    Idle 17-20
    Part Throttle 6-14
    WOT 15, 22
    I will load a stock lq4 file in and change that <20 to a 14 as stated. I noticed from 9000 hz up the lq4 has lesser numbers than my numbers now (which would make things leaner at wot). I will be adding 2% fuel in that area to be safe. Sound good?
    Followed by some scans. But in general isn't up to 7500 hz beneficial enough for a maf tune? or do you go higher?
    Once that is all set do I need/really need any fancy PID's or numbers for the wot/afr portion of the maf tune? Or just go about how I did that part before?
    02 Regal GS
  17. #57 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    Yep correct no fancy equations for wot and yes 7500 is plenty.add your 2% and get on with your maf tune!
  18. #58 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    I really do appreciate this! Thank you.
    I will try this out this weekend hopefully.
    Do I need to unplug my 02 to force it into open loop when doing the maf tune? Or is this only needed for the wot portion?
    Will some smoothing need to be done as well of the maf? Selection.
    02 Regal GS
  19. #59 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    No need to unplug your 02 to my knowledge. Unless its a weird "3800ism" that needs to be done . remember open loop does not use fuel trims.(some gm os will allow this but most dont)so you can't tune maf via fueltrims in open loop. Once you hit pe or wot that will freeze trims and run in open loop at the Afr you set.
    As for smoothing I don't believe in it. I like us I g the exact numbers the scanner tells me.
  20. #60 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Jul 2008
    Hooksett,NH
    Gotcha!
    I could have sworn "darkhorizon" stated that he tunes afr/wot in open loop. Due to the fact that in closed loop you are "tuning" your narrowbands as the pcm sees the trims. If all the trims are spot on then there should be no worry? But maybe its a preference thing?
    At the beginning of this thread I afr/wot tuned with it plugged in then with it unplugged. The afr was spot on each time. I also can't say anything about "pro tunes" on the dyno. I don't know if they force open loop.
    At least I can start on the maf tune and get to the afr/wot portion after. As I did it backwards.
    02 Regal GS
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. Pulley / Timing / MAF tuning with elevation change
    By Impala131 in forum PCM Tuning
    Last Post: 02-21-2013, 04:15 PM
  3. 1998 Regal GS Tuning Question
    By DrGSXR750 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 04:38 PM
  4. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
