Thread: Tuning a l67 with air to air I/c and blow thru setup
Results 1 to 5 of 5
  1. #1 Tuning a l67 with air to air I/c and blow thru setup
    SE Level Member hdnseek's Avatar
    Jun 2013
    Des Moines Iowa
    Looking for someone to shed some onsight on tuning difficulty with a blow thru setup with a a2a core and m90 with a blow thru setup. What would need to be down with the boost bypass valve, is it replaced by the blow off valve? Also how much tuning would need to be done with a a2a and blow thru??
    Heres a blow thru roots supercharger on an f body.
    Sent from my SAMSUNG-SM-T217A using Tapatalk
    Tuning a l67 with air to air I/c and blow thru setup Attached Images
  2. #2 Re: Tuning a l67 with air to air I/c and blow thru setup
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i think if u leave the bbv alone you wont need a blowoff valve as it wont make boost unless it is closed not sure on the tuning part of it looks sick though should put on on the other side for looks LMAO
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Tuning a l67 with air to air I/c and blow thru setup
    Feb 2009
    flintnasty MI
    PCV may cause issues if you are using the throttlebody before the MAF sensor.. If it causes issues try plugging it if you didnt have to with the air/air. Pics would help.
  4. #4 Re: Tuning a l67 with air to air I/c and blow thru setup
    Jun 2013
    Des Moines Iowa
    It'll go maf then tb, elimination of bbv replaced with bov would readings be the same before the supercharger and after in using a fmic, roots blowers don't actually compress any air cores t so flow should be same draw threw vs blow thru??
    Sent from my HTC One mini using Tapatalk
  5. #5 Re: Tuning a l67 with air to air I/c and blow thru setup
    Feb 2009
    flintnasty MI
    BBV wouldnt make a difference either way. just because air loops around the blower doesnt mean any more or less air is coming into the system. You just need to measure net draw into the motor as effectively as possible which isnt hard at all. You'll never need a blow off as there is no air pushing against a throttle blade.. The only reason people use blowoffs is to not bend throttle blades and prevent turbo compressor surge... you have no risk of either.
    I noticed you have another thread regarding this.. and if you are worried about the driveby internet naysayers saying its impossible to tune these.. i would probably wait and see myself. From experience I would say that a maf sensor responds the best when it is placed as close as possible to the intake valves... Without that you will want to introduce what we would call an "interp" or "AE" factor on the throttle position which will compensate for the now "measurable" pressure lag you would have with a massive intake plenumn.
  1. Now with less white and more function.
    By machinegunsquid in forum Members Rides
    Last Post: 02-26-2016, 01:43 AM
  2. Replies: 9
    Last Post: 09-12-2011, 05:59 PM
  3. Taillight blow out
    By jluca in forum General Tech Discussion
    Last Post: 12-04-2010, 08:22 PM
  4. blow out
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 11-26-2009, 06:14 PM
