Thread: Jets flash tuner
Results 1 to 7 of 7
  1. #1 Jets flash tuner
    SE Level Member 13aceofspades13's Avatar
    Oct 2013
    Ionia
    is it compatible for the Grand Prix GP? there website says it is but i want too make sure... would any of you guys or gals know?
  2. #2 Re: Jets flash tuner
    Only HP tuners or a DHP tuner can "tune" your grand prix.
    Nothing else works, both cost more and require alot more time and knowledge to learn how to tune.
  3. #3 Re: Jets flash tuner
    Oct 2013
    Ionia
    tuning things like air too fuel ratio? fuel injector duty cycle? shift points? ignition timing? i am guessing these tuners you speak of you have too manually adjust these things which takes time and practice...
    do they have aftermarket PCMs for the L-26 engine?
  4. #4 Re: Jets flash tuner
    I think so?
    But your 2008 can't be tuned, the pcm and can-bus systems don't allow for it.
  5. #5 Re: Jets flash tuner
    Oct 2013
    Ionia
    alright, thanks for the help.
  6. #6 Re: Jets flash tuner
    HUDSON
    Yes, JETS will tune, I have 14005 model, there is an update ate the JETS that allows it to program the v6 cars also.
  7. #7 Re: Jets flash tuner
    Feb 2009
    flintnasty MI
    Jets works on 97 to 03. Check their website or tunercats website for further compatibility.
  1. Trying to flash 97 pcm to stock with HPT
    By ASCStinger in forum PCM Tuning
    Last Post: 03-31-2013, 01:28 PM
  2. Replies: 1
    Last Post: 06-13-2012, 05:46 PM
  3. EGR delete w/o PCM Flash
    By GP98GTX in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-02-2012, 06:09 AM
  4. flash floods
    By oneil.GTP in forum Off Topic Discussion
    Last Post: 05-18-2010, 12:22 AM
