Thread: Security tuning question
Results 1 to 9 of 9
  1. #1 Security tuning question
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    How do I disable security in pcm.... I was told it was turned to false in secirity drop down menu and the number value is set to 255... I think factory is 0 the problem is the car cranks consistently but dies 3-5 seconds later... It doesnt try to continue running no matter if I peddle gas pedal or what... Ive tried everything and all is left is pcm.... And my tuner is thinking security is issueso help please
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: Security tuning question
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    and body codes set in the vtd module?
  3. #3 Re: Security tuning question
    brunswick
    i have no idea what a vtb module is... im working on monte carlo ss 2003 model
  4. #4 Re: Security tuning question
    Sep 2013
    Calgary, Alberta
    if your problem is a vehicle theft deterrent issue. dtc will be set in the vtd module.
  5. #5 Re: Security tuning question
    I don't remember the exact name. Look for something like injector pulse disable timer. It'll be set to something like 4, IIRC it's 0 you want. That keeps the injectors from being disabled by the pcm.
  6. #6 Re: Security tuning question
    brunswick
    ok.. and does this issue sound like a crank or cam sensor issue? the car starts consistently and dies in the exact same time frame.. 5 seconds from running to death
  7. #7 Re: Security tuning question
    Not at all.
    Cam sensor gives the engine a 1:6 chance of starting, crank sensor also has different symptoms.
  8. #8 Re: Security tuning question
    brunswick
    alright last question.. will any serial to usb adapter work for the dhp tuner or does it absolutely have to be keyspan
  9. #9 Re: Security tuning question
    I have a radioshack one. I've heard that some didn't work, not sure which ones. A few guys I know had the shack adapter and I just bit the $30 bullet on it.
  1. tuning question...
    By jjmitch87 in forum PCM Tuning
    Last Post: 10-10-2013, 02:14 PM
  2. 02 GP GT Coupe Security Question???
    By 02GPinNY in forum Audio, Security & Visual Electronics
    Last Post: 08-15-2012, 06:56 PM
  3. Question about tuning
    By Joshmoshh in forum PCM Tuning
    Last Post: 05-04-2012, 06:15 PM
  4. Tuning question
    By Impalass in forum Shops and Community Heroes
    Last Post: 04-04-2012, 10:29 PM
  5. security system question
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2011, 05:37 PM
