I had this problem a few weeks ago after a few times hooking up the pcm with hpt. Couldn't figure it out so I pulled all wires from the pcm connectors to tidy everything up and re hook it all back up and everything worked fine. The other day I took out the coilpack/icm to remount it and since then I get the error "unable to locate vcm. verify the cable is connected and the key is in the run position." This 3800sc swap is in a fiero that I have yet to fire up.
