Thread: Maxed out maf table at 67lbs?!?!
Results 1 to 8 of 8
  1. #1 Maxed out maf table at 67lbs?!?!
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    So on my setup I already scaled the 60lb injectors back 30% for e85 and I have a ls2 maf. Im hitting aprox 10,875hz on the table occasionally so I dont need a maf scaler yet. Tuning has gone well so far and I have everything below 7500hz locked in at 2% or less. My issues are with 7500hz+ because im maxing out the table at 67ish lbs. Im guessing taking the injectors down another 20% and then taking the maf table down another 20% will take care of it but I just wanted to make sure.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: Maxed out maf table at 67lbs?!?!
    Feb 2009
    flintnasty MI
    Something is wrong. You should be able to use a stock LS2 maf table, which doesnt even pretend to max out. If you are tuning the maf at all there is a mechanical issue, I have never needed to tune a LQ4, LT1, or a stock maf car's maf table before.
  3. #3 Re: Maxed out maf table at 67lbs?!?!
    Apr 2011
    South Dakota
    When I switched from stock maf which was nearly perfect to ls2 maf and table everything was off by 15+ percent wideband and narrowband. No way just changing the maf caused my entire fuel system to shift 15%.
    I love Decker<3
  4. #4 Re: Maxed out maf table at 67lbs?!?!
    Feb 2009
    flintnasty MI
    Figure out whats wrong then. I usually just start with a stock tune, then dial the injectors in where they need to be on a stock maf table.
  5. #5 Re: Maxed out maf table at 67lbs?!?!
    May 2008
    Schuyler, NE
    You've got issues. No way your MAF table is even close to correct. Go back to your stock table, and check everything over.
  6. #6 Re: Maxed out maf table at 67lbs?!?!
    Apr 2011
    South Dakota
    All i did was scale injectors down 30%... Idk where i could have messed up
    I love Decker<3
  7. #7 Re: Maxed out maf table at 67lbs?!?!
    Feb 2009
    flintnasty MI
    scaled injectors, then your maf table magically added 50%?
  8. #8 Re: Maxed out maf table at 67lbs?!?!
    Apr 2011
    South Dakota
    I changed maf table after scaling. Ill mess with the tune and zzp fpr tomorrow
    I love Decker<3
  1. P0171 Code LTFT Maxed @ Idle
    By dbextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2019, 01:38 AM
  2. P0171 Code LTFT Maxed @ Idle
    By dbextreme in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2013, 10:36 PM
  3. MAF table?
    By GTP4 in forum PCM Tuning
    Last Post: 12-17-2008, 09:41 PM
  4. Maxed Out = BS
    By Dboy23 in forum General Tech Discussion
    Last Post: 09-21-2008, 12:55 AM
  5. Eddie's table modifier, my table too big?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-06-2008, 09:00 PM
