How much does it take to raise narrow band 02 roughly 100 mv?
I dont know how much i need to add since i put on the 3.5 pulley and headers right now 02 are in the low 800 with 2-3 degrees of knock.
100 kpa is already 215
but the PE is still stock. I dont want to hit the invisible timing table during a WOT run.
any suggestions on how to get the fueling up because 100 mv sounds like a lot to just add a the injectors.
Here is a small scan from tonight. 50+ miles for trim learn
RACETRACK_11-19-2008_5_25_32_P from detroitlions34 -- Scan Depot dot net
the pcm is still pulling fuel during cruise even though I did not change anything from the stock tune MAF/VE in the cruise area. Doesnt headers usually cause the car to run more lean? If so why is mine still pulling fuel?
Sorry it is a crappy scan traffic was everywhere and 02 of 820 at WOT scare me even though i dont have a Wideband.
I am surprised that i am getting so little kr for running lean
Thank you
