Thread: L36 to L67 swap PCM Question
Results 1 to 5 of 5
  1. #1 L36 to L67 swap PCM Question
    SE Level Member JEBSR's Avatar
    Clarksville, Tn
    I just completed an L67 swap in my daughters 99 GP. When I bought the engine I got the entire frame, suspension, steering, and PCM out of a wrecked 99 regal. When I installed the engine and trans I hooked up the BBV and extended the MAP wiring, Put the regal pcm in and get no CEL. Put my scan tool on and it says the VIN doesn't match the BCM. I can put the factory PCM back in and start it up but the MAF sensor acts up. Not sure if it's bad or just confused by the boost that it doesn't know what to do with since it runs great at times and ****ty at others. My original plan was to have the VIN changed in the regal PCM and assumed that would work since all the programming is already correct in that PCM. However when I called the guy that normally updates my pcm's when I swap one he told me that if he changed the VIN in the PCM it would work but the BCM would revert the programming back to whatever it should be for the VIN I use, i.e. the l36 tune. This doesn't make since to me, is it correct or is he mistaken? I know I could just have the L67 table put in my factory PCM but haven't found anyone close that can do it. So bottom line, can I just change the vin in the regal pcm or do I just need to send in my factory pcm and get it programmed?
    If it has Tits or Wheels, it's nothing but Trouble
  2. #2 Re: L36 to L67 swap PCM Question
    Florida
    you just need to have the vin changed in the regal pcm. but it is possible the guy might not be able to update vin without changing the entire program.
  3. #3 Re: L36 to L67 swap PCM Question
    Clarksville, Tn
    I kind of figured that would work, but wanted to make sure. Thanks for the info..
  4. #4 Re: L36 to L67 swap PCM Question
    Feb 2009
    flintnasty MI
    I dont see why you would need to change the vin over.. the BCM error will just cause the airbags to not work or something stupid for right now until you resync the pcm to the BCM.
  5. #5 Re: L36 to L67 swap PCM Question
    Clarksville, Tn
    I read something similar when searching for an answer. Someone said it didn't matter until around 03 or something like that. But when I plug it in everything works but I have no CEL so it won't start. The only code is the BCM PCM VIN mismatch.
  1. DIC swap question..
    By greenprix00 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2013, 12:51 AM
  2. DIC swap question..
    By selym17 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2012, 12:15 PM
  3. Top Swap'n Question
    By BillBoost37 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2011, 08:06 AM
  4. top swap question.
    By turbo6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 07:14 PM
  5. ....And yet another Top Swap Question...
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2010, 06:27 AM
