Thread: Top Swapped L26 hpt file
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
  1. #1 Top Swapped L26 hpt file
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Any of you guys have one that you're willing to share or at least some base tune? I am ridiculously far off.
    Il
  2. #2 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    What have you done so far? what car? what year? injectors? maf? pulley? blower?
  3. #3 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Yeah it would have made sense to include all if that info haha.
    Blended inlet Gen V
    1.8 roller rockers
    42.5 injectors
    Heads ported just enough to smooth out casting flaws.
    Cold air fenderwell intake
    Sent from my SPH-D710 using Tapatalk 2
  4. #4 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    2007 GP L26 bottom end
  5. #5 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Stock MAF
  6. #6 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    4.0 pulley
  7. #7 Re: Top Swapped L26 hpt file
    May 2008
    Schuyler, NE
    Start with a stock MAF table, and input the table for 42.5lb injectors. What year is your car?
  8. #8 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    I was using the MAF table from and 05 GTP and I fixed my injector tables last night.
    Above 7000hz on MAF frequency I lock in Power Enrichment. Did 10.0:1 to be safe. Writing with 11.0:1 right now.
  9. #9 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
  10. #10 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    And my battery craps out on me. Didn't have that in my budget. Damn.....
  11. #11 Re: Top Swapped L26 hpt file
    May 2008
    Schuyler, NE
    Do you have a wideband?
  12. #12 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Yes I do
  13. #13 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    PE entry should be about 25% throttle. Other than that make your commanded PE vs coolant about 12.5, it should command about 11.5 on the scan at that point assuming the rest is stock.
  14. #14 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    That doesn't seem too lean? I'm commanding 10 now and seeing 13.2 on the wideband and some knock. I had PE at 30% too. May try 25. After tonight I'm giving it a break. Commanding so rich is really sucking down the tank.
  15. #15 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    Quote Originally Posted by jlgp2007nc View Post
    Its not going to make a noticeable mpg difference...
  16. #16 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    I know, but I still have to give it a break for now. Still knocking all over the place. Using AL 104 plugs. Maybe I'll go to 103s this weekend.
  17. #17 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    You put L67 timing in correct? Start out with about 14 degrees or so if you are having issues.
  18. #18 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    No I put in L32. Used file from an 05 GTP. VE table scaled for L67 MAP sensor that im using.
    Do you have HPT? I think I can upload a scan file here right?
  19. #19 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Nah just tried. I don't think I can upload that here.
  20. #20 Re: Top Swapped L26 hpt file
    May 2008
    Schuyler, NE
    You can email it to me, and I'll take a look at it, if you want. Send the file that you are running too.
    nick_04sc@hotmail.com
  1. need a dhp bin file for 99 gtp
    By onalky87 in forum PCM Tuning
    Last Post: 06-18-2012, 11:32 PM
  2. Need a Bin File
    By SerenityGTO in forum PCM Tuning
    Last Post: 06-08-2011, 01:14 PM
  3. need dhp bin file
    By nascartech in forum PCM Tuning
    Last Post: 11-20-2010, 11:50 PM
  4. Transmission bin file to another bin file?
    By Pure2sin in forum General Tech Discussion
    Last Post: 11-10-2010, 07:11 PM
  5. DHP file
    By TheOtherNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 02:51 PM
