Any of you guys have one that you're willing to share or at least some base tune? I am ridiculously far off.
Il
Yeah it would have made sense to include all if that info haha.
Blended inlet Gen V
1.8 roller rockers
42.5 injectors
Heads ported just enough to smooth out casting flaws.
Cold air fenderwell intake
Sent from my SPH-D710 using Tapatalk 2
Start with a stock MAF table, and input the table for 42.5lb injectors. What year is your car?
2007
I was using the MAF table from and 05 GTP and I fixed my injector tables last night.
Above 7000hz on MAF frequency I lock in Power Enrichment. Did 10.0:1 to be safe. Writing with 11.0:1 right now.
Do you have a wideband?
PE entry should be about 25% throttle. Other than that make your commanded PE vs coolant about 12.5, it should command about 11.5 on the scan at that point assuming the rest is stock.
That doesn't seem too lean? I'm commanding 10 now and seeing 13.2 on the wideband and some knock. I had PE at 30% too. May try 25. After tonight I'm giving it a break. Commanding so rich is really sucking down the tank.
I know, but I still have to give it a break for now. Still knocking all over the place. Using AL 104 plugs. Maybe I'll go to 103s this weekend.
You can email it to me, and I'll take a look at it, if you want. Send the file that you are running too.
nick_04sc@hotmail.com
